Internet of the Backyard
  • Internet of the Backyard
Blog RPI B+ and the EnOcean Sensor Kit Overview of Up Comming Blogs and Videos
  • Author Author: Robert Peter Oakes
  • Date Created: 4 Sep 2014 4:22 AM Date Created
  • Views 1681 views
  • Comments 7 comments
  • enocesn
  • iot_backyard
  • enocean-pi
  • rpib+
  • internet_of_things
  • raspberry_pi
  • raspberrypi
  • iot
Robert Peter Oakes
Robert Peter Oakes
4 Sep 2014
This is an introduction to two videos I am producing to show the setup of the new RPI B+ and then the installation of the EnOcean Pi module and first time use of the Sensor Kit
The PI Setup including WIFI Raspberry PI Model B+ Quick Set-up (1/2 Hour Guide from unpack to GUI and WIFI)
EnOcean and Fhem setup Raspberry Pi B+ and the EnOcean Sensor Kit - install and initial testing
you will se in the videos that the process to go from boxed PI B+ board and empty SD card to a working system is no more than about 30 Minutes
Then you will see how the prep and subsequent install of the EnOcean drivers and Fhem home automation software will take over an hour to complete due to a rather long process of updating the firmware and libraries of the PI, but be patient, it will get there
In later videos we will look at publishing out the data from the PI to the internet web site EVRYTHNG - Every Thing Connected where you can track, personalize and generally watch / manage your IoT device, go have a look, it is an interesting site and you may find it handy for one or more of your projects
    DAB over 12 years ago
    Good post Peter,
    I am curious about the switches powering the transmitter.  Does any of the documentation indicate how much energy they generate?
  • Robert Peter Oakes
    Robert Peter Oakes over 12 years ago in reply to DAB
    not that I have seen, I will see if i can safely take it apart, I still need to use it for videos, if not ill keep an eye out for info on that for you
    DAB over 12 years ago in reply to Robert Peter Oakes
    Ok, no rush.
    Just curious.  I can see some useful designs with that capability.
