Internet of the Backyard
  • Internet of the Backyard
Forum Have a question for TI re: The Internet of the Backyard Challenge? Ask here!
  • Replies 39 replies
  • Subscribers 8 subscribers
  • Views 5871 views
  • iot_backyard
doctorcdf
doctorcdf over 12 years ago
This thread is dedicated to questions for the Internet of the Backyard challenge; Texas Instruments' staff will be monitoring it regularly.
Thanks!
  • Robert Peter Oakes
    Robert Peter Oakes over 12 years ago in reply to BigG +1
    It looks like the is a FET switch configured to protect against reverse voltage and should also protect the batteries from harm if the USB or other supply is also connected (Q2 bottom right)
  • bwelsby
    bwelsby over 12 years ago in reply to DAB +1
    DAB wrote: What is the APP needed to open the CCS 6 download? I got the same message on Windows 8.1 and 7. The TI message indicated that they were .exe files, but when I tried to change the name…
  • janisalnis
    janisalnis over 12 years ago in reply to e14 Contributor +1
    Registering at Plotly is free of charge for everyone. Limitation, I read somewhere, is that it would allow to store 50 plots. Is there an simple HTTP POST example for CC3200? There is a GET function used…
    Robert Peter Oakes over 12 years ago in reply to e14 Contributor
    QUOTE:
    After being selected, you'll also be given access to Plotly, the web's premier data streaming and visualization software. Plotly has written code specifically designed to make it easy to get your backyard data to the Internet. Just imagine what you could do: the possibilities are endless.
    Once every two weeks, you'll post a blog entry showing us how you're getting on. The final build needs to be finished by October 3. Winners will be selected on October 13... and the prize?
    even without a library, every contestant should be able to write code to do this
    it is a challenge after all and with an amazing prize for the winner, that should take effort to win and im talking about a significant effort both in software, hardware and artistry/creativity, not just pulling a few libraries together
    the community will help of course, you only have to ask, but each one of you must be prepared to research, learn and document
    Good luck
    This is not aimed at you in particular but all too often road testers / contestants seem to take the easier road and replicate other peoples work, in some cases verbatim and that is not what this is about, sure borrow and modify other peoples code, ideas etc but make them your own
    if something does not exist, create it (Plotly Library for example) , the reward is worth the effort
    Peter
    a quick update
    Just discovered a member has got plotly to work, in linux using curl but the info is there and it should be fairly straight forward to convert to your use
    IoT live data upload to Plotly and Xively
    e14 Contributor over 12 years ago in reply to Robert Peter Oakes
    My question about Plotly was because there was no mention of login in the congratulation email I got or in the dev kits received, so the 'given access' confused me. I created a login as it appears to be open to public. Just wanted to verify there was not a specific account I was required to use for the contest, or that I missed a step.
    thanks,
    Bill
    There would be a unique one set up for you, I am not sure of the process but @doctorcdf    may be able to point you in the right direction
    regards
    Peter
  • BigG
    BigG over 12 years ago
    Another general question, just to help fashion platform of understanding. Often in wireless sensor networks you would use or create a repeater to extend or resolve black spots. I would typically start by looking for off the shelf devices (e.g tp-link nano is a handy cheap little repeater device.) to get me started. As cc3200 already provides 3 operating mode settings I wondered what it would take to use cc3200 as a repeater.
  • BigG
    BigG over 12 years ago in reply to Robert Peter Oakes
    The closest library I could find which I'm looking at is a plotly library found on the mbed platform but it may be easier for me anyway just to create script that is specific to my app. I believe you can also use json encoding to send payload data.
  • doctorcdf
    I'm pleased to say that you can now use the Eclipse IoT Platform with the CC3200: click here.
  • BigG
    I tried a quick help search for the MAP_UtilsDelay, UART_PRINT functions using my CCS help option but zero results came up. Where would I need to look to get a reference to these functions.
    DAB over 12 years ago
    The TI message indicated that they were .exe files, but when I tried to change the name it blew up.
    e14 Contributor over 12 years ago in reply to DAB
    Got the same issue, did not do this in previous version. I ended up downloading the .zip, extract the files and install from there.
