Light Up Your Life
  • Light Up Your Life
Light Up Your Life
Forum Technical Support Thread | Light Up Your Life Design Challenge
  • News
  • Projects
  • DC
Join Light Up Your Life to participate - click to join for free!
  • Replies 20 replies
  • Subscribers 48 subscribers
  • Views 2102 views
  • design challenge
  • e14-Würth Elektronik
  • würth elektronik
JoRatcliffe
JoRatcliffe over 1 year ago
I wanted to kick off a thread and share some more information to help inspire anyone considering signing up and inform everyone who is selected as a Challenger.
This is just a starting point and everyone is very welcome to ask questions, either directed at Nicola (Würth Elektronik ) from Würth Elektronik or myself (JoRatcliffe ). Plus, everyone is free to use this space to share any additional resources they find useful or discoveries related to the kit.
The centrepiece of the kit is the Würth Elektronik ICLEDs (Integrated Controller Light Emitting Diodes).
{gallery}The LEDs!
: This is how the LEDs arrived - in reels like this - here at our office.
: We will be dividing up the reels between all the Challengers. However, for convenience we will not be separating each LED individually.
: Hope this made for a fun little insight into the behind-the-scenes of Design Challenges.
Würth Elektronik’s RGB ICLEDs are advanced lighting solutions that are equipped with an integrated controller capable of PWM dimming. The inclusion of an integrated controller in each ICLED eliminates the need for complex circuitry and difficult PCB layouts. With a single microcontroller unit (MCU) transmitting information to the initial ICLED in a chain, subsequent ICLEDs receive the data through daisy-chain connections, simplifying the overall setup without requiring extra connections to the MCU.
Files & Documentation
Product URL for Reference
Manufacturer Part Number
Farnell SKU
Specs & Documentation
https://uk.farnell.com/wurth-elektronik/1315050930002/led-rgb-625-525-470nm-120deg/dp/4420411
1315050930002
4420411
Datasheet
EDA models & CAD file downloads
Würth Elektronik ICLED SDK (GitHub repository)
https://uk.farnell.com/wurth-elektronik/1313210530000/led-rgb-625-525-470nm-120deg/dp/4420407RL
1313210530000
4420407RL
Datasheet
https://uk.farnell.com/wurth-elektronik/1312020030000/led-rgb-625-525-470nm-120deg/dp/4420406RL
1312020030000
4420406RL
Datasheet
https://uk.farnell.com/wurth-elektronik/1312121320437/led-rgb-625-525-470nm-110deg/dp/4420409RL
1312121320437
4420409RL
Datasheet
https://uk.farnell.com/c/optoelectronics-displays/led-products/standard-multicolour-leds-under-75ma?st=1315050930246
1315050930246
4683764
Datasheet
https://uk.farnell.com/c/optoelectronics-displays/led-products/standard-multicolour-leds-under-75ma?st=1311610030140
1311610030140
4683765
Datasheet
The design challenge’s kit also includes an Arduino Zero (ABX00003). Würth Elektronik shared with me these design schematics for the Featherwing which I have uploaded to the Files section of this Design Challenge to help provide an initial technical insight into how the LEDs can be used.
https://uk.farnell.com/arduino/abx00003/arduino-board-32bit-arm-cortex/dp/3874819
ABX00003
3874819
Datasheet
Pinout
Schematics
ICLED_SDK libraries for the Feather M0 Express microcontroller
Get Started, CAD files, Compatibility & Suggested Libraries
The rest of the challenge's kit has not been forgotten but the key items above are mainly the ones that have been discussed so far in the challenge group. Files and documents shared here are correct as of 7th August 2025. This is intended as a ‘snapshot in time’ of the files and documents and will not be updated.
  • robogary
    robogary over 1 year ago in reply to obones +3
    Maybe, depends on your interpretation of monster. 100 LEDs at 20 mA each is 2A , not a big deal, but a separate PS is needed.The controller wont power it. I built an led light organ using a 12v 10a power…
  • JWx
    JWx over 1 year ago in reply to Anthocyanina +2
    I think it was meant to be mcd:
  • misaz
    misaz over 1 year ago in reply to embeddedguy +2
    Look at their webpage. There are datasheet, brief explanations, link to application note and most notably, recording of webinar, which explains lot of things including some best practices. https://www…
  • misaz
    misaz over 1 year ago in reply to CADi_Master
    They are not fully compatible but almnost every task you can somehow achieve with both. I gues you can use UNO R3 instead of provided Zero in your project as well. But Zero is more modern and has faster CPU, so give a try. Biggest difference is likely that UNO R3 use 5V logic while newer Zero is 3.3V.
    While current content terms and conditions does not say anything about it, in history it was mandatory to use at least two parts from kit, but usage of whole kit was not mandatory.
  • embeddedguy
    embeddedguy over 1 year ago
    Is there any specific document for circuit design using this LEDs from Wurth? Like things to consider and best practices etc?
  • misaz
    https://www.we-online.com/en/components/products/WL-ICLED
  • arvindsa
    arvindsa over 1 year ago in reply to misaz
    misaz  If this 14.5 you are referring referring to Max I(F,IC) of  1315050930002, then it is the IC Output current to each individual IC. Take a look at ANO009 (https://www.we-online.com/components/media/o782907v410%20ANO009b_Understanding%20parameters%20in%20ICLED%20datasheets_EN.pdf) at page 4, it says the Value you are probably referring to is per LED and therefore when all thee lights are turned on at fuull brightness, it will be 14.5x3mA obones do check out the document
  • embeddedguy
    embeddedguy over 1 year ago in reply to misaz
    So, I looked at basic schematic from the above and found that there was no capacitor on one of the schematics using LEDs.?
    And also, I saw some documents and one webinar on the link you have posted, there was not much on PCB or circuit design best practices.
  • arvindsa
    arvindsa over 1 year ago in reply to embeddedguy
    decoupling caps? you should definitely put it. 100nf near each LED and may me 10uF around start of each strip. if the LED color isnt gonna drastically change (gently fade from zero) you can get away without individual caps for each LED.
  • misaz
    I do not know what schematics you refer to. Even simplified schematics on directly linked page shows capacitors.
    I did not watch full webinar, but If there are not any concrete PCB layout requirements, follow standard one (ground plane under LEDs, wide VCC trace because high currents flow through it, etc).
  • embeddedguy
    Ok. look on the first schematic. BTW this is not serious because, I always follow the standard rules as much as I can. So, I know the above rules. Nevertheless, if there is any specific parameter in that case such guides can help us. That's why.
    Files - element14 Community
  • embeddedguy
    embeddedguy over 1 year ago in reply to arvindsa
    Thanks man..!
  • misaz
    Ahh, now I understand what schematics you mean. On this schematics, following caps serves the purpose:
    It works because featherwing is pretty small board and LEDs are still near the caps. But if you do something longer, I would recommend staying at old good 100nF near each chip (LED).
