Light Up Your Life
  • Light Up Your Life
Light Up Your Life
Forum Single LED test (#2)
  • News
  • Projects
  • DC
Join Light Up Your Life to participate - click to join for free!
  • Subscribers 49 subscribers
  • Views 142 views
ZephyrusBlaze
ZephyrusBlaze over 1 year ago
Single LED test: color cycle update
Hey everyone, I finished the first tiny milestone with the sponsored kit and wanted to share how it went. I tested one 5050 breakout LED to make sure the board and the code talk to each other, and it worked way better than I expected. Feels nice to see a pixel light up after all the waiting.
Quick setup I used
I soldered one LED onto a breakout and wired it up to the Arduino Zero. For the test I powered the LED from 5 V, tied grounds together, and used a single data pin from the Zero. The LED cycled through red, green, and blue so I could confirm colors and timing.
Wiring summary: VDD to 5 V, VSS to GND, DIN to Arduino pin 6, DOUT left unconnected.
Code I used
#include <Adafruit_NeoPixel.h>
Adafruit_NeoPixel strip(1, 6, NEO_GRB + NEO_KHZ800);
void setup() {
  strip.begin();
  strip.show();
void loop() {
  strip.setPixelColor(0, strip.Color(255,0,0));
  strip.show();
  delay(500);
  strip.setPixelColor(0, strip.Color(0,255,0));
  strip.show();
  delay(500);
  strip.setPixelColor(0, strip.Color(0,0,255));
  strip.show();
  delay(500);
What happened
The LED came alive exactly like in the code: red, then green, then blue, repeating. I recorded a short video so you can see the colors and the timing. There was a tiny flicker the first time I powered it because my wiring was loose, but reseating the jumper fixed it. Overall it was a quick win and a good confidence booster.
Video
Next steps and plans
  1. Solder a column of 5 breakouts and test chaining DOUT to DIN.
  2. Compare one clocked LED column against a non-clocked column to see timing differences and more stable updates.
  3. Work out power distribution for the full 10x5 grid so I do not get brownouts.
I will post another update after the 5-LED chain test with pictures and another clip.
