Make Life Accessible
  • Make Life Accessible
Blog Description of the Device
  • Author Author: fyaocn
  • Date Created: 15 Apr 2016 6:24 AM Date Created
  • Views 899 views
  • accessibility_projects
fyaocn
fyaocn
15 Apr 2016
This device is fixed on one side of injured elbow, Accel/Gyro sensors fixed on this side of equipment can provide the motion status of arm. With pattern matching arithmetic, the movement of the arm is calculated. Base on the results, the direction and force applied on the actuator shall be calculated. Converted signal triggers PWM control on motors.
This device can add extra power for arm movement,  and reduce pains if the elbow is still hurt.
Original design has more than two sensors installed. Precise sampling in RTOS shall be applied to reduce errors. So, I revise the design and improve the arithmetic to achieve similar result with only one sensor. Refer to the following sketch,image
  • fyaocn
    fyaocn over 10 years ago +1
    Great advice on this design. Just like your keenly observation, in fact, there are two rotary axis for form arm movement. Two motors is needed if control both. As far as I know from preliminary research…
    DAB over 10 years ago
    You might want to consider using a motor on each side.
    Your current design might cause the elbow joint to twist.
    You could also probably use velco straps to attach the device to the arm, though using a couple of solid bands for better strength distribution.
