Make Life Accessible
  • Make Life Accessible
Blog Make Life Accessible - ELapShelf - Getting it all together - Blog 8
  • Author Author: rsc
  • Date Created: 13 Jun 2016 3:37 PM Date Created
  • Views 825 views
  • design challenge
  • motor control
  • accessibility_projects
  • mla
  • nxp
rsc
rsc
13 Jun 2016
The gears on the shelf are not working very well.  I need to add bearings to the inside shafts to lower the drag and torque on the motor.
Lining up gears with just shafts in holes in the wood is a bit tricky.
The current solution looks like this:
For the next blog I'm hoping to be able to show a video of the shelf operating.
    DAB over 10 years ago
    You are putting a lot of mechanical stress on your pivot point.
    I can see how your implementation would easily become unbalanced and increase the resistance to the turning motion.
    I would suggest adding a vertical member to the shelf and using a large hinge to take all of the stress of a loaded shelf.
    You could then just use a simple lever to move the shelf in and out.
