MusicTech
  • MusicTech
MusicTech
Blog Kazumi - 14 - Drum Sounds
  • Author Author: luiszayas
  • Date Created: 11 Apr 2016 11:41 AM Date Created
  • Views 1691 views
  • music tech
  • mtc
  • bbb
  • project_kazumi
  • music
  • music-tech
  • kazumi
luiszayas
luiszayas
11 Apr 2016
This entry shows how Kazumi can be used to play drum machine sounds.
The responsiveness of the instrument, thanks to the ultra-low latency Bela platform, makes it perfect for percussive instruments. I wanted to try this with some classic drum machine sounds.
The Pure Data patch uses the excitation from the piezos to trigger the drum samples, which are stored in arrays. This is one of the subpatches:
Here is a video of how this sounds at the moment(I'm an amazing drummer as you can see image):
In the future, I want to use the audio input to be able to record your own samples on the instrument itself and play it back with a different pitch for every pad. Or even use it as a source for granular synthesis.
  • carmelito
    carmelito over 10 years ago
    This sounds awesome ! thanks for all the info on your projects..
  • luiszayas
    luiszayas over 10 years ago in reply to carmelito
    Thank you! I haven't had a proper look at your project yet but it seems like it would be great with Bela in it!
  • luiszayas
