MusicTech
  • MusicTech
MusicTech
Blog PlectralEffects Update
  • Date Created: 14 Feb 2016 2:20 AM Date Created
  • Views 675 views
  • plectraleffects
e14 Contributor
e14 Contributor
14 Feb 2016
If you are curious as to the status of my project.  I am still awaiting parts, the BeagleBone Black and the majority of the parts have not arrived -- Currently, I have been testing physical prototypes of the plectrum itself.  I have decided, mainly due to limited availability of parts on hand to try a conductive based approach.
The plectrum will be constructed as a sandwich... No, not a cheese and onion sandwich but rather a construction of conductor -> insulator -> conductor.  Both conductors will be fed to an amplification circuit to detect conduction to a steel string common return, possibly ground on the audio pickup jack of an electric guitar.
I will have to test the conductivity between the contact point and string, but a simple amplifier should ensure that even higher levels of resistance could create an appropriate trigger level for the BBB controller :
On my next blog post, I will connect up the plectrum prototype to a microcontroller,  that I have on hand (possibly not the BBB) for further processing.
  • fraktalize
    fraktalize over 10 years ago
    Hey! Nice to see you're getting started! I can't really grasp how you plan on making everything come together, but I hope I will understand  more in your next update.
    (Also weird that you haven't received your kit either... Seems like nobody has..?)
  • fraktalize
