MusicTech
  • MusicTech
MusicTech
Blog Sacrificial Violin
  • Author Author: selement14
  • Date Created: 21 Feb 2016 4:59 PM Date Created
  • Views 1840 views
  • Comments 6 comments
  • project_violin
  • music tech design challenge
Sacrificial Violin
selement14
selement14
21 Feb 2016
The video you are about to witness, can be difficult to watch, as it was a bit difficult to make.  The idea of taking a perfectly good Violin and sacrificing it to the good of the project takes some serious will power. Especially if you have never dissected a Violin before.  But I needed a basis for my project so I ordered one of those inexpensive, Violins from Amazon, and set out to modify it.  WARNING: This video contains Violin violence, and some viewers, who appreciate classical instruments may have difficulty watching. For the rest of you, enjoy.  -- Now posted to the right spot. image
  • rsc
    rsc over 10 years ago +1
    You need to get a Dremel
  • selement14
    selement14 over 10 years ago in reply to fraktalize +1
    I had several issues uploading the video the element14 itself but after several attempts it is finally uploaded. Not sure about using HTML5 vs insecure flash player. I'd say that is a question for the…
    shabaz over 10 years ago +1
    Hehe this is history in the making - surely the only video on the Internet showing how to slice a violin with a sander : )
  • fraktalize
    fraktalize over 10 years ago in reply to selement14
    Sure, I could use a VM! It's just a shame that proprietary software is required to watch the video.
    I take it you don't want to upload it to mediagoblin or some other site which has HTML5-support? image
  • selement14
    I had several issues uploading the video the element14 itself but after several attempts it is finally uploaded.  Not sure about using HTML5 vs insecure flash player.  I'd say that is a question for the element14 Feedback and Support team. You can always load a virtual machine(VM) and use the insecure flash player in there to watch the video.  That way, it is "walled off" from your system software.  Worst it can do if used properly is infect the VM.
  • fraktalize
    Any way you could add the video to somewhere with HTML5 video support? I would love to watch it but I avoid using the insecure Flash Player image
  • selement14
    selement14 over 10 years ago in reply to rsc
    I had a similar thought part way through the process.  It would have left a smoother surface, and much easier to work around the nooks and crannies of the violin face. All in all it still turned out okay.
