Path II Programmable
  • Path II Programmable
Forum PIIP - PetaLinux 2018.3 Installation missing files
  • Subscribers 5 subscribers
  • Views 1803 views
  • path ii programmable
ralphjy
ralphjy over 7 years ago
This is a question for my fellow trainees.  I just discovered that I'm missing some files from my PetaLinux install and I just wanted to ask whether others are having this problem or if I have made an error installing or am using a corrupt install.
I normally run the SDK from the shortcut icon on my VM desktop and that has been working fine.  In PetaLinux Lab 4 the SDK is started from the command line - xsdk and that failed because it couldn't find the Java runtime required by the SDK (it was a warning but it failed to start).  When PetaLinux was installed the instructions were to modify the .bashrc file so that the PATH was changed to point to the PetaLinux install files.  The JRE files are missing from my PetaLinux file tree (/tools/petalinux-v2018.3-final) but are there for the Xilinx file tree (/tools/Xilinx).
I copied files to eliminate the jre problem but encountered more missing files.
Anyone else have this problem?  If not I'll have to hunt for why I am missing files.
Ralph
  • danzima
    danzima over 7 years ago
    nerdyupdates
    jarios86
    avnrdf
    buffteethr
    cmelement14
    dcsoutherner
    ianrj
    aspork42
    vladrumyan
    Hi all, does anyone have any advice for Ralph about the above issue?
  • buffteethr
    buffteethr over 7 years ago
    Sorry. I have not gotten to the Petalinux labs yet.
  • aspork42
    aspork42 over 7 years ago
    Which labs is that for? I tried launching SDK from command line and it didn't work, but the desktop shortcut worked fine with no ill side effects that i've noticed. I've done labs 1-4 and am finishing tonight.
  • ralphjy
    ralphjy over 7 years ago in reply to aspork42
    Thanks, I guess I was looking for confirmation that starting the SDK from the command line did not work.  You probably have the same issue.
  • cmelement14
    cmelement14 over 7 years ago in reply to danzima
    The problem is not because the installation misses files, but because the lab instruction forgot to mention the step of setting up environment before starting up SDK.
    Here's a sequence of commands you need:
    export SWT_GTK3=0
    . /tools/Xilinx/SDK/2018.3/settings64.sh
    xsdk &
