Path to Programmable 3
  • Path to Programmable 3
Blog Blog 4: Continuation on Software Training |Path to Programmable 3|
Join Path to Programmable 3 to participate - click to join for free!
  • Author Author: prashanthgn.engineer
  • Date Created: 27 Jul 2023 8:58 AM Date Created
  • Views 703 views
  • Ubuntu
  • AMD XILINX
  • 18.04
  • zynq
  • ultrascale+
  • vivado
  • ultra96
  • embedded
  • Ultra96-V2 Board
  • vitis
  • linux
27 Jul 2023
Software Training
Lesson 6: Connecting Hardware and Debugging
Summary of Lesson6
  • Ultra96 V2 Hardware Explanation
  • How to Debug the application using RUN configuration
  • Setup for Processor initialization, RESET, Download Bit steam, Terminal and Profiling
Lab 5– Connecting Vitis to Hardware
Experiment 1: Setup Hardware and Download Bitstream
{gallery}Lab 5
Debug an Application
{gallery}Debug an Application
Lesson 7: First Stage Boot Loader
Summary for Lesson 7
  • First Stage Boot loader (FSBL) for Zynq UltraScale+ MPSoC configures the FPGA with hardware bitstream (if it exists) and loads the OS Image or Standalone Image
  • Standalone PL configuration without PS is not possible
  • configuration of FSBL by external host is by JTAG mode
  • Secure and non Secure Boot Modes
  • Can boot from 4 Master Boot Devices : QSPI, NAND,eMMC and SD
  • Slave Boot Devices : JTAG and USB2.0
  • Zynq Ultrscale+ Boot Flow
What does FSBL Does
  • Initialize Processing system
  • Initialize PLL, External memory and MIO
  • configure PL with bitsream
  • Provide option for Secure Boot Modes
  • Execute Application Code
Boot Flow Diagram
PMU Boot
  • configuration both PMU and CSU
  • Validates PLL clocks
  • Clear PSU and CSU RAM
  • Validate LPD AUX Unit
CSU Boot
  • initiate on chip memory.
  • Determine boot mode
  • Loads FSBL on OCM
  • Execution by R5 or A53
  • CSU loads PMU;s Firmware
Stage 2 Boot
  • Loads Uboot and Runs DDR
  • Loads OS and Kernal Images
  • OS is loaded from NAND/QSPI/USB/Ethernet/Sd
LAB6 : First Stage Boot Loader (FSBL)
{gallery}My Gallery Title
Lesson 8: SD Card and Boot-up
  • using Viti's Create Boot Image Wizard.
  • File order should be: First Stage boot loader, Bitstream and Application: File order matters.
  • To Flash QSPI, we can use Vitis Program Flash memory utility  Wizard
    • Multiple non volatile types
    • .BIN and .MCS Format Files
    • Programming at Offset
    • Erase check verify option
ULTRA96-V2 Does not have QSPI
LAB7 : Boot from SD
{gallery}SD boot
Lesson 9: Vitis Project Management
  • Walk through on the VITIS IDE
  • Store the repositions: Include custom Files
LAB 8 : Explore Workspace
{gallery}Explore Vitis
Lesson 10: Interrupts
Summary for Lesson 10
Interrupt means some interface or peripheral needs an Immediate Response or attension
Hardware Interrupts
  • Asynchronous changes in Hardware
  • Generating outside the processor
  • IOndiactes peripherals needs an attention immediately.
Software Interrupts
  • Synchronous event in software needs for a change in execution.
  • Also called an Exception.
Lab 09 : Interrupts
Lesson 11: AMD Xilinx Libraries
  • System allows range of Different Libraries
  • Power management
  • Single FAT Generic File System
  • TCP IP Support - Open Source
  • Secure Programming eFUSE
  • In System Serial programming
  • Libraries can be added within BSP Settings
LAB 10 : AMD Xilinx Libraries
Learning with Element14 Continues
Regards
Prashanth Kumar G N
