Path to Programmable 3
  • Path to Programmable 3
Forum Question about Zynq Software installation
Join Path to Programmable 3 to participate - click to join for free!
  • Replies 7 replies
  • Subscribers 129 subscribers
  • Views 5013 views
  • petalinux
  • vivado_version
  • Path Programmable III
  • minized
taifur
taifur over 3 years ago
From Lab 0 I understand that for completing the training course I need to install AMD-Xilinx Vitis and Vivado ML Edition 2021.1. For installing the tools an Ubuntu Linux LTS 18.04.04 running on a windows virtual machine is recommended. My question is may I use Ubuntu Linux LTS 18.04.04 OS directly without running it in a virtual machine? I have a Ubuntu OS installed on my PC.
  • saadtiwana_int
    saadtiwana_int over 3 years ago +3
    That should not be an issue as such. The only thing that can happen is if your VITIS installation goes bad (and you're not a Linux wizard). It has happened to me in past and the easiest way out was to…
  • rscasny
    rscasny over 3 years ago +1
    You should not need to purchase a license. If you are being asked to purchase a license. Don't respond here and I'll contact someone to help. Randall element14
  • saadtiwana_int
    saadtiwana_int over 3 years ago in reply to taifur +1
    I'm curious to know if you can go through all the labs using the latest version of tools and petalinux. The training is based on 2021.2 and sometimes things don't work across different versions so well…
  • saadtiwana_int
    That should not be an issue as such. The only thing that can happen is if your VITIS installation goes bad (and you're not a Linux wizard). It has happened to me in past and the easiest way out was to start over with an earlier VM snapshot. But if it's installed on the PC directly then you can't do that.
  • flyingbean
    flyingbean over 3 years ago
    Ubuntu 18.04.x might have less uncertainties than Ubuntu 22 since Xilinx did more testing for Vitis 2021.1 on Ubuntu 18.04.x. I am going to use Ubuntu 18.04.x for Vitis 2021.1 on MiniZed for this design challenge.
  • taifur
    taifur over 3 years ago in reply to flyingbean
    Ok then I will try Ubuntu 18.04.x
  • rscasny
    Randall
    element14
  • taifur
    Finally installed the Vitis 2023.1 successfully on my Ubuntu 20.4 PC.
  • taifur
    taifur over 3 years ago in reply to taifur
    PetaLinux 2023.1 is also installed successfully
  • saadtiwana_int
    I'm curious to know if you can go through all the labs using the latest version of tools and petalinux. The training is based on 2021.2 and sometimes things don't work across different versions so well. Please do post back here once you've completed the trainings. I myself wanted to go for the latest tool versions but in the end went with 2021.2 to avoid issues with training materials.
