Path to Programmable 3
  • Path to Programmable 3
Forum Did anyone get a build error in Lab 4 pointing to missing file xp[arameters.h?
Join Path to Programmable 3 to participate - click to join for free!
  • Subscribers 129 subscribers
  • Views 2538 views
ciorga
ciorga over 3 years ago
Hello Path to Programmable 3 participants,
I am stuck in software training lab 4 with a build error pointing to missing file "xparameters.h".  Did anyone get to this error when trying to build Lab4 project application?
Cosmin
  • javagoza
    javagoza over 3 years ago +3
    Hi! I solved that problem editing the pwm driver makefile. Open the xsa with a zip editor. I used 7zip then edit the file Makefie Change contents by this one. The problem is with wildcard * …
  • ciorga
    ciorga over 3 years ago in reply to javagoza +2
    Thank you javagoza for your help. The fix that you have posted worked for me. I am now able to build the project without any errors.
  • javagoza
    javagoza over 3 years ago in reply to javagoza +1
    ciorga tested with the same 2022.2 version
  • javagoza
    COMPILER=
    ARCHIVER=
    CP=cp
    COMPILER_FLAGS=
    EXTRA_COMPILER_FLAGS=
    LIB=libxil.a
    RELEASEDIR=../../../lib
    INCLUDEDIR=../../../include
    INCLUDES=-I./. -I${INCLUDEDIR}
    INCLUDEFILES=*.h
    LIBSOURCES=$(wildcard *.c)
    OUTS = *.o
    OBJECTS = $(addsuffix .o, $(basename $(wildcard *.c)))
    ASSEMBLY_OBJECTS = $(addsuffix .o, $(basename $(wildcard *.S)))
    libs:
    	@echo 'Compiling PWM_w_Int'
    	$(COMPILER) $(COMPILER_FLAGS) $(EXTRA_COMPILER_FLAGS) $(INCLUDES) $(LIBSOURCES)
    	$(ARCHIVER) -r ${RELEASEDIR}/${LIB} ${OBJECTS} ${ASSEMBLY_OBJECTS}
    	make clean
    include:
    	${CP} $(INCLUDEFILES) $(INCLUDEDIR)
    clean:
    	rm -rf ${OBJECTS} ${ASSEMBLY_OBJECTS}
    Then update specification and clean build the hardware platform
  • javagoza
  • ciorga
  • navadeepganeshu
    navadeepganeshu over 3 years ago
    I faced the same issue. Later migrating to the recommended Vitis version only worked for me. I do get what javagoza suggested, but that did not work and was unable to understand why that happened while importing the .xsa platform in the older version of Vitis(I was in 2020.1). Would it be about the PWM driver version incompatibility where the newer revision is called in 2021.1 generated .xsa which is inexistent in the older library set (as of vitis 2020.1)?
  • javagoza
    javagoza over 3 years ago in reply to navadeepganeshu
    The OP wanted to go to a higher version of Vitis, going to a previous version is definitely a different problem and I don't think a priori it can work.
