Path to Programmable 3
  • Path to Programmable 3
Forum I am getting this error. Can anyone please help me in solving it ?
Join Path to Programmable 3 to participate - click to join for free!
  • Replies 8 replies
  • Subscribers 127 subscribers
  • Views 3247 views
  • ultra96
  • Path Programmable III
manojroy123
manojroy123 over 3 years ago
  • bidrohini
    bidrohini over 3 years ago +1
    Here is a thread about this error message: support.xilinx.com/.../could-not-find-arm-device-on-the-board-for-connection-local-zynq-ultrascale-mpsoc-zcu102
  • flyingbean
    flyingbean over 3 years ago +1
    Why did you use zcu106/platfomr.spr for Ultra96 board? Ultra96 is not zcu106 FPGA.
  • manojroy123
    manojroy123 over 3 years ago +1
    This problem solved by loading custom platform that was build using Vivado ,changing the BSP setting and powering on the board by pressing switch SW4 .
  • saadtiwana_int
    saadtiwana_int over 3 years ago
    This means Vitis cannot detect your board (via JTAG path).
    Make sure:
    - The board is connected via the USB-to-JTAG
    - The board is powered up
    - The mode on your board is set to boot from JTAG
    It helps to know  what board you're using? Is it the Ultra96-v2 or minized?
  • manojroy123
    manojroy123 over 3 years ago in reply to saadtiwana_int
    I am using Ulra96-v2. The board is powered on. JTAG pod is tested using serial COM terminal application and it is working properly. I am still getting the error. the boot mode is set to JTAG.
  • bidrohini
    shabaz over 3 years ago
    Also, are you really running it on Windows 8?!
    Are you sure that's supported?
  • flyingbean
  • manojroy123
  • kpham
    kpham over 2 years ago in reply to saadtiwana_int
    I'm having the same problem. But my board is the Microzed. Like manojroy123 , I have made sure all the connections are there, but the problem still persists. Could you point me in the right direction?
  • kpham
    kpham over 2 years ago in reply to manojroy123
    What's the custom platform? I can't find it
