Path to Programmable
  • Path to Programmable
Blog Received the first Training Module
  • Author Author: mconners
  • Date Created: 30 Sep 2018 1:45 PM Date Created
  • Views 986 views
  • Likes 9 likes
  • Comments 5 comments
mconners
mconners
30 Sep 2018
Ok. This post won't be all that exciting. I received an email from Randall with the instructions to download the Training modules. Haven't received the hardware yet, but I figured I could at least get my dev environment set up.
I downloaded a zip file, extracted it and found a directory laid out like this:
I went into the Lab_instructions directory, and found the following
I opened up the file named ZynqHW_2017_4_lab_0_v7.pdf and it was as I suspected, a pre setup lab.
It basically told you what software they had used to develop the lab and what you needed to install on your computer.
They had used Windows 7,  Vivado 2017.4, and Tera Term. I'm already causing problems, my environment is Linux, and I'll probably use a different terminal emulator, but I did download Vivado 2017.4.
I followed the instructions to install, and it immediately said there is a newer version available, and asked if I wanted to download it. I said yes, so hopefully I'll be able to complete the labs with the newer version.
I'm sure it won't be a problem...
So, here it is. Software installed. Waiting for the hardware to show up. I guess I'll spend some time reading the other PDF files.
Until next time.
  • michaelkellett
    michaelkellett over 8 years ago +4
    Don't count on things working if you use the wrong version of Viavado - at the very least you will be plagued by warnings and requests to update components. At the worst stuff just won't work. I'm not…
  • aspork42
    aspork42 over 8 years ago +3
    My first reaction when looking over the materials - “Oh crap - there is a LOT of training ahead of us!” Looks like an entire semester’s worth of curriculum. Excited to get rolling but jeesh - there is…
  • mconners
    mconners over 8 years ago in reply to aspork42 +1
    It's all good. I can't wait to get the board! That's when the rubber hits the road. Mike
  • aspork42
    Excited to get rolling but jeesh - there is a lot to get through. Going to have to budget my time accordingly.
  • aspork42
  • mconners
    Mike
