PiCasso Design Challenge
  • PiCasso Design Challenge
Blog PiCasso Design Challenge - PiMassive - Blog #2 - CNC Time
  • Author Author: gam3t3ch
  • Date Created: 2 May 2019 7:00 PM Date Created
  • Views 921 views
  • picasso
  • cnc
  • picasso design challenge
  • raspberry pi 3b+
  • art
  • pimassive
gam3t3ch
gam3t3ch
2 May 2019
So each step seems to have its pros and cons today I prepared a video for you on the carving process
So the program I am using for carving is  https://www.vectric.com/products/vcarve-pro   And the CNC I will be using is my MPCNC version 1 which has gotten a ton of revisions in the last 4 years but mine is still going strong so no sense in upgrading it quite yet.   Certainly will be making a newer one for a laser engraver in the future.
You can make your own as well its on thingiverse.com and here is the link to the site where you can buy the kits https://www.v1engineering.com/
So lets start with where we left of from Blog #1 the main design here.  but the best part! on to the video check it out.
So that took a lot longer then expected.  Mind you it was paused while I slept so take a bit off the end time there but not much.
Oh right before I forget lets have a look at the holes being cut as well.
Next up will be printing components so on to the fun to make sure I have everything to scale and then will do the cleaning and prep work for everything and a ton of painting.
Note to self, Plywood is probably not the best for this project but with the time invested in it I am determined to make it work.
a little teaser for next post here is the headphone jack being printed.
https://www.instagram.com/p/Bw8RFGuhmqb/
Making process and will get more posted soon so make sure to check in and follow my progress.
  • gam3t3ch
    gam3t3ch over 7 years ago in reply to davedarko +2
    you bet well try to seems I have to blow my models up a bit and do a bunch of separation on the models. sketchup is not playing nice with it tho right now will see what happens. so far GPIO is good to…
  • davedarko
    davedarko over 7 years ago +1
    Are you planning on adding these snap-in headers?
  • davedarko
  • davedarko
  • gam3t3ch
    you bet well try to seems I have to blow my models up a bit and do a bunch of separation on the models. sketchup is not playing nice with it tho right now  will see what happens. so far GPIO is good to be working and will get the others done up first then will have to do some redesign and revisiting.  Still playing with ideas lots to come tho.
