PiCasso Design Challenge
  • PiCasso Design Challenge
Blog PiCasso Design Challenge - PiMassive - Blog #6 - Time to Hang the Pi
  • Author Author: gam3t3ch
  • Date Created: 31 May 2019 6:07 AM Date Created
  • Views 949 views
  • Likes 8 likes
  • picasso design challenge
  • raspberry pi 3b+
gam3t3ch
gam3t3ch
31 May 2019
I was really curious of how I was going to mount the unit knowing full well the weight but not wanting have it fall.
Gorilla Glue to the rescue!
I have used it in so many projects why stop now it has not failed me yet.
So what about hanging it?
Well I grabbed out my bandsaw set it to a 45 degree angle and decided I would make a french cleat for hanging it
This way I could make sure I was screwed into the studs and it would be able to hand whatever I put on it.
So with it mounted on the wall finally I could store it on the wall while I dealt with the printed parts more since there was a ton of painting and printing that still had to happen.
When dealing with massive parts and a massive Raspberry Pi 3B+  you tend to make a Massive mess to go along with it.
Lets have a look make sure its in the right spot.....
Not too bad I must say!
OK now its hanging up its time to get the 3d printed parts together and set on the board so  lets have a closer look into that in the next post.
  • dixonselvan
    dixonselvan over 7 years ago +2
    gam3t3ch that is a massive hang! So can I suggest some Edge lit to PCB like this one (for a table) - https://youtu.be/SaG-NQ64540?t=211 or simply you can add LED strip to the back edge such that the PCB…
    shabaz over 7 years ago +2
    Hi Wesley, That looks really great! In the second photo, I honestly thought it was some real Pi PCB you'd managed to find.. at first glance I could not tell that the scale was massive : ) I bet there's…
  • dixonselvan
    So can I suggest some Edge lit to PCB like this one (for a table) - https://youtu.be/SaG-NQ64540?t=211 or simply you can add LED strip to the back edge such that the PCB will have a glow in the dark!
  • dixonselvan
