PiCasso Design Challenge
  • PiCasso Design Challenge
Blog PiCasso Design Challenge - Post 7 Part 2
  • Author Author: dwinhold
  • Date Created: 3 May 2019 12:48 AM Date Created
  • Views 1510 views
  • Likes 11 likes
  • Comments 7 comments
  • pov globe
  • picasso design challenge
  • dwinhold
dwinhold
dwinhold
3 May 2019
Welcome back for the 2nd part of my 7th blog. This part is the motor turning the globe, proving the sewing maching motor works. The video below shows it working.
Thank you
Dale W
    balearicdynamics over 7 years ago +5
    Dalem very great progress! I like the sound of this motor when runs; you saved the memory of the sewing machine sound. It remembers ancient moments when I was a kid and this sound was frequently present…
  • dwinhold
    dwinhold over 7 years ago in reply to balearicdynamics +5
    Hi Enrico I did run the globe for 15 minutes non-stop at high speed. The only issue I found was a slight vibration. The cause is the globe ring isn't 100% balanced yet (which I knew before). I even ran…
    balearicdynamics over 7 years ago in reply to dwinhold +5
    Hello Dale, I think that 15 minutes is already a good test. If nothing has broken, there are boog possibilities that it will rung for a very long period without problems. Enrico
  • e14phil
    e14phil over 7 years ago
    That poor Raspberry Pi is going for a spin dry!
  • dwinhold
    dwinhold over 7 years ago in reply to e14phil
    It is a G-force Pi test!!
  • dwinhold
