PiCasso Design Challenge
  • PiCasso Design Challenge
Blog PiCasso Design Challenge - POV Globe Blog 3
  • Author Author: dwinhold
  • Date Created: 4 Apr 2019 12:49 AM Date Created
  • Views 1257 views
  • Likes 10 likes
  • Comments 9 comments
  • pov
  • pov globe
  • picasso design challenge
  • led
  • dwinhold
  • globe
dwinhold
dwinhold
4 Apr 2019
Hi everyone,
This weeks update is a bit more then I figured. I got quite a bit completed on the building of the globe. As you will see I created the base for the globe, top part to support the north end of the globe and have the LED's attached. I am trying to see if I can make it more 3D by giving it depth with a second row of LED's on the inside of the globe. This way I can produce 2 pictures at 2 different depths at the same time. As always, anyone want any of the .dxf files for this project please ask, I will send them out!!
Below are pictures of the globe so far:
Outside row of LED's
Inside Row of LED's
Support post in the bearings
I had to firgue out how to power the RPi and the LED's. Since the globe is spinning, I can't just run the power cord to the hardware for obvious reasons. I plan on using the bearings as the power connection. One for the positive and one for the negative. I will attach one half of the wire to the outside of the bearing and the other half to the inside. Hope it works!!
Below is a very short video of the globe turning (By hand) no motor is hooked up yet.
This will be my next blog, hooking up the motor.
Thank you for reading,
Dale Winhold
    balearicdynamics over 7 years ago +6
    Good progress, Dale. I appreciate the cleanliness of the design, very well done. Enrico
    dubbie over 7 years ago +6
    Dale, A very smooth turning action. The bearings must be working well. Have you given any thought to the wind or draught that might be created? For a flicker free image you might need to rotate at 50 revolutions…
  • maegeph
    maegeph over 7 years ago +6
    I've seen someone using an audio jack to transfer power, very clever idea https://hackaday.com/2009/10/15/72-led-persistence-of-vision-globe/
  • e14phil
    e14phil over 7 years ago
    Hey Dale,
    How about a Slip Ring.
    https://www.newark.com/adafruit/736/slip-ring-with-flange-22mm-d6/dp/85W1855?st=slip%20ring
    P
    • Vote Up +5 Vote Down
    Dale,
    A very smooth turning action. The bearings must be working well. Have you given any thought to the wind or draught that might be created? For a flicker free image you might need to rotate at 50 revolutions per second or maybe only 25 revs per second if using both sides of the globe. which is going to move a lot of air around.
    Dubbie
    • Vote Up +6 Vote Down
    Enrico
    genebren over 7 years ago
    Dale,
    That is looking pretty cool.  I like the approach that you took to power your raspberry Pi through the bearings.  I am using some slip rings on my project to power moving arms and so far they are working well.
    Keep up the good work!
    Gene
