PiCasso Design Challenge
  • PiCasso Design Challenge
Blog PiCasso Design Challenge - POV Globe Blog 3
  • Author Author: dwinhold
  • Date Created: 4 Apr 2019 12:49 AM Date Created
  • Views 1133 views
  • Likes 10 likes
  • Comments 9 comments
  • pov
  • pov globe
  • picasso design challenge
  • led
  • dwinhold
  • globe
dwinhold
dwinhold
4 Apr 2019
Hi everyone,
This weeks update is a bit more then I figured. I got quite a bit completed on the building of the globe. As you will see I created the base for the globe, top part to support the north end of the globe and have the LED's attached. I am trying to see if I can make it more 3D by giving it depth with a second row of LED's on the inside of the globe. This way I can produce 2 pictures at 2 different depths at the same time. As always, anyone want any of the .dxf files for this project please ask, I will send them out!!
Below are pictures of the globe so far:
Outside row of LED's
Inside Row of LED's
Support post in the bearings
I had to firgue out how to power the RPi and the LED's. Since the globe is spinning, I can't just run the power cord to the hardware for obvious reasons. I plan on using the bearings as the power connection. One for the positive and one for the negative. I will attach one half of the wire to the outside of the bearing and the other half to the inside. Hope it works!!
Below is a very short video of the globe turning (By hand) no motor is hooked up yet.
This will be my next blog, hooking up the motor.
Thank you for reading,
Dale Winhold
    balearicdynamics over 6 years ago +6
    Good progress, Dale. I appreciate the cleanliness of the design, very well done. Enrico
    dubbie over 6 years ago +6
    Dale, A very smooth turning action. The bearings must be working well. Have you given any thought to the wind or draught that might be created? For a flicker free image you might need to rotate at 50 revolutions…
  • maegeph
    maegeph over 6 years ago +6
    I've seen someone using an audio jack to transfer power, very clever idea https://hackaday.com/2009/10/15/72-led-persistence-of-vision-globe/
    genebren over 6 years ago in reply to dubbie
    I am using slip rings in my Picasso project. (https://www.newark.com/adafruit/775/accessory-type-slip-ring/dp/42X3604?st=slip%20ring ).  Here are some of the details (PiCasso Design Challenge - Kinetic Art Mobile - Post 2 )
    So far they are working great.  I will be doing some more testing on these soon to see if I can quantify the noise on lines.
    Gene
    dubbie over 6 years ago in reply to 14rhb
    This is good to know. I've never seen a proper slip connector for transferring power before.
    Dubbie
  • 14rhb
    14rhb over 6 years ago
    Hi Dale,
    That is a very professional project build - even the woodwork looks really accurate. Well done so far, I'm looking forward to your blog #4.
    Rod
    • Vote Up +6 Vote Down
  • dwinhold
    dwinhold over 6 years ago in reply to dubbie
    Hi Dubbie
    Speed is something I will have to be playing with. G-force, wind and draught is a bit of a concern and will have to be dealt with if it becomes a problem.
  • maegeph
