PiCasso Design Challenge
  • PiCasso Design Challenge
Blog PiCassoTizer - The Wand - Blog 7
  • Author Author: dougw
  • Date Created: 19 May 2019 8:30 AM Date Created
  • Views 1466 views
  • Likes 11 likes
  • Comments 5 comments
  • doug wong
  • picassotizer
  • picasso design challenge
  • wand
dougw
dougw
19 May 2019
I decided the PiCassoTizer needs a wand to act like a touch screen paint brush with mouse functionality.
I was going to give it a fancy name, but all the cool names I thought of sounded too pretentious.
The features it needs are:
  • and ergonomic grip
  • a reflective pointer
  • 2 microswitches to emulate mouse buttons
  • a debounce circuit to permit accurate button activity
The following video shows the wand construction, the circuit and its performance:
Here is a picture of the switches wired on a strip board with 2 SPDT microswitches:
This is the debounce circuit implemented on the circuit board:
Here is what the 3D printed wand looks like:
Here is what the circuit board and switches look like when inserted in the wand:
Here is what the cable looks like in its channel:
Here is a picture showing typical switch bounce (in green) and the cleaned up output (in yellow):
This part of the project is relatively simple, but it takes a surprising amount of time to design, build, troubleshoot and blog about something even this simple.
Next I will try to get the DACs working....
Then build frames for the cameras and computers...
Then put it all together and adjust the geometry and the software ...
Then attempt some art...
Relevant links:
PiCassoTizer - Introduction - blog 1
PiCassoTizer - Electronic Parts - Blog 2
PiCassoTizer - Finger Detection Image Processing - Blog 3
PiCassoTizer - Absolute Mouse Position - HID Simulation - Blog 4
PiCassoTizer - The Snowman Smiles - Blog 5
PiCassoTizer - Pi Expanse - blog 6
    balearicdynamics over 7 years ago +5
    I start seeing the light, Doug, a very good new step. The design of the wank looks very good, a mix between ancient and new tech. Do you plan to close the circuit side too? BTW, I am sure you will get…
    DAB over 7 years ago +5
    Good idea, what better to do point and click than a wand. DAB
    genebren over 7 years ago +4
    Nice addition to your project! Looks like a good ergonomic design. Gene
  • 14rhb
    14rhb over 7 years ago
    Never seen anything quite like that before, it is great image. Great progress Douglas.
    Rod
  • 14rhb
    Rod
