Rocking Raspberry Pi
  • Rocking Raspberry Pi
Forum All the Raspberry pi GPIO pins are occupied by Wolfson audio card... :( need access to GPIO :(
  • Replies 10 replies
  • Subscribers 5 subscribers
  • Views 2976 views
  • wolfson_pi
  • rockingraspberrypi
  • raspberrypi
  • rocking_pi
  • wolfson_microelectronics
indiant3chi3
indiant3chi3 over 12 years ago
H3ll0  all !!
Is there any other way to access the Raspberry pi  GPIO pins ..?? Since all the pins are occupied by wolfson card need help image plzzz...
  • rohitrangwani
    rohitrangwani over 12 years ago +1
    Check out these links rpi.gpio - Getting more than 26 GPIO pins - Raspberry Pi Stack Exchange Expand the Number of GPIO Pins on the Raspberry PI #piday #raspberrypi @Raspberry_Pi « adafruit industries…
    e14 Contributor over 12 years ago +1 suggested
    Two of the Raspberry's GPIO pins on the P1 header are made available on the Wolfson card. They are normally used as the UART serial console, but that function is easy to disable. http://www.hobbytronics…
    e14 Contributor over 12 years ago in reply to indiant3chi3 +1
    Yes, most ultrasonic sensors I have seen use two GPIO pins. You can use the pins on the Wolfson card to connect it. -- Ragnar
  • rohitrangwani
    0 rohitrangwani over 12 years ago
    Expand the Number of GPIO Pins on the Raspberry PI #piday #raspberrypi @Raspberry_Pi « adafruit industries blog
    Raspberry Pi MCP23017 Port Expander Board Kit | RPI-PORTEXP | HobbyTronics link for Raspberry Pi MCP23017 Port Expander Board Kit.
    These basically discuss how to extend no. of gpio of pins but it is up to you to decide how to use them and configure the accessory attached to gpio pins(here PIface i think).
  • indiant3chi3
    0 indiant3chi3 over 12 years ago in reply to rohitrangwani
    Thanks  for the links Rohit, image
    I'm planning to connect a ultrasonic sensor with the pi is there any other option ??
  • rohitrangwani
    0 rohitrangwani over 12 years ago in reply to indiant3chi3
    Ultrasonic Distance Measurement Using Python – Part 1 | Raspberry Pi Spy
    Check this link for connecting a ultrasonic sensor and I dont think there is any option other than gpio pin extension.
    well but you could use external usb sound card in place of wolfson.And then use gpio pins for anything you want to do.
    http://www.hobbytronics.co.uk/raspberry-pi-serial-port
    Raspberry Pi • View topic - Easily disable / enable serial console
    Then the two pins can be used as ordinary GPIO pins.
    Ragnar
  • indiant3chi3
    0 indiant3chi3 over 12 years ago in reply to e14 Contributor
    Hi Rangar!!!
    First of all thanks a ton for ur wolfson image contribution. And now thanks again for this GPIO clarification ... image . can i connect Ultrasonic sensor in this wolfson card  ? is that possible ?
    0 e14 Contributor over 12 years ago in reply to indiant3chi3
    Ragnar
    actually,I suggest you can try about another board same function as Raspberry PI named BANANA PI.Now it's popular~I heard from my friend about that,if you need more information,please contact me~miyali@sinovoip.com.cn
    The Wolfson Sound Card doesn't fit on the Banana Pi.
    Ragnar
  • dimonic
    0 dimonic over 12 years ago in reply to e14 Contributor
    From the schematic, I take it that the audio card uses the i2c pins (1.3 and 1.5) on the header - can I still connect to these pins for another i2c device?
    0 e14 Contributor over 12 years ago in reply to dimonic
    Yes, you can. I2C bus is designed for multiple devices.
