Save The Bees Design Challenge
  • Save The Bees Design Challenge
Blog Bee Healthy - Blog 5: Edge Impulse Model
Join Save The Bees Design Challenge to participate - click to join for free!
  • Author Author: ralphjy
  • Date Created: 19 Feb 2023 6:13 AM Date Created
  • Views 2565 views
  • Likes 18 likes
  • Comments 9 comments
  • save the bees
  • bee hive audio
  • savethebeesch
  • nicla vision
  • audio impulse design
  • edge impulse
  • buzz3 dataset
ralphjy
ralphjy
19 Feb 2023
I've selected the Buzz3 Audio Dataset to test model development and deployment to the Nicla Vision board using the Edge Impulse toolset.  I discussed this dataset in my previous post - Bee Healthy - Blog 4: Audio Dataset.
The Buzz3 dataset contains 11746 2sec samples split as follows:
train
class hour min samples
bee 1 36 2880
cricket 2 0 3600
noise 1 24 2520
test
class min sec samples
bee 35 42 1071
cricket 19 14 577
noise 36 36 1098
I may end up rebalancing the training data, but I'll try it out first.  I already have an Edge Impulse account , so I just needed to create a new project that I named Bee_Present:
A great feature of the Edge Impulse Studio is the ability to upload existing data files provided they are in an accepted data format or file type.
Data Acquisition Formats:
  • CBOR
  • JSON
  • CSV
File Types:
  • WAV
  • JPG
  • PNG
  • AVI
  • MP4
The audio files in this dataset are all WAV files, so uploading the files with the appropriate labels was easy.
Data Acquisition
Impulse Design
For non-voice audio data it is generally recommended to use a Spectrogram Processing block - either linear or MFE (Mel-filterbank energy).  The MFE is designed to match human audio perception.  One might expect MFE to perform better because the data was labeled by human listeners.
I decided to try it both ways.
Audio (MFE) Impulse
Train the Neural Network:
The Quantized (int8) model accuracy is reasonable when validated against the training data:
But performs less well against the test data as would be expected:
Linear Spectrogram Impulse
Again, reasonable accuracy with the training data
But worse performance against the test data
Summary of Project versions:
The inference time of the Mel Spectrogram Impulse (35ms) is half of the Linear Spectrogram Impulse (71ms).  And it also has better memory efficiency and accuracy (with this dataset), so that's the model that I will use.
My first test when I get the Nicla Vision hardware will be to use the microphone to verify that I can do "Live classification" before I try to deploy the model.
    DAB over 3 years ago
    Nice update.
    I wonder if it could detect killer wasps attacking a hive?
    Nice update.
  • ralphjy
    ralphjy over 3 years ago in reply to DAB
    I'm sure it could, but hopefully there wouldn't be a lot of data of this type.  I have heard the audio of a hive that became "Africanized" and when they swarm to attack - it is clearly distinct from normal swarming.  Have not found a dataset of that though.
