Save The Bees Design Challenge
  • Save The Bees Design Challenge
Blog Save the Bees - Machine Learning
Join Save The Bees Design Challenge to participate - click to join for free!
  • Author Author: dougw
  • Date Created: 20 Feb 2023 11:46 PM Date Created
  • Views 2399 views
  • Likes 15 likes
  • Comments 7 comments
  • TwoBee or not TwoBee
  • save the bees
  • huskylens
  • savethebeesch
dougw
dougw
20 Feb 2023
Intro
The project kit has not arrived yet, but I want to keep the project moving with another interesting post. This blog covers recognition of various bugs by a computer vision system that uses machine learning to identify the various bugs. It also introduces the interface PCB, 3 of which will be used - one for each system node.
Bug Recognition
This video shows the HuskyLens in action recognizing 2 different bees, a spider, a cicada, a grass hopper and a ladybug.
HuskyLens
I tried to zoom in on the HuskyLens display....it isn't as dark as the camera implies...
In case you are wondering how much work is involved in training the HuskyLens to recognize insects, the next video is a quick demo of how the HuskyLens is trained to recognize multiple objects.
Machine Learning Simplified
Although I find the buttons a bit awkward, the designers of HuskyLens did a lot of work to make this powerful little system simple to train and use. In case you are wondering about the technology - the Huskylens uses a Kendryte K210 dual core RISC-V processor.
System Review
The Arduino MKR WAN 1300 will be used as the controller in each of 3 nodes in the system. To do this, a PCB was designed that allows interfacing all the different peripherals in each system. All three nodes will use the same PCB with a MKR WAN 1300, but each node will have different peripherals and will have different firmware. Actually one of the nodes will also be built in 2 different configurations, one will feature a HuskyLens and the other a Nicla Vision module.
Interface PCB Design
The PCB can connect an Arduino MKR WAN 1300 to 3 different cameras, 3 different LCD displays, 2 different speech synthesizer modules and an audio amplifier.
Here is the interface schematic:
The PCB has been laid out and ordered and will be described further when it arrives.
Discussion
Some progress has been made on machine training, insect recognition and PCB design. However the project feels like it is off the rails. The build period is scheduled to run from Jan 4 to March 17 and the project kit has not been received yet. There is a lot of work left to be completed with less than a month remaining. It is great to see the HuskyLens vision system in action. I am impressed with its power.
Next steps
In the next blog the HuskyLens will be connected to an Arduino MKR WAN 1300 to allow it to use names for each bug instead of generic labels.
When the new speech module arrives, the Arduino MKR WAN 1300 will be able to respond to Husky recognized bugs and give each critter its own voice.
When the project kit arrives the work of communicating what the edge system has discovered will begin.
Links:
 Two Bee Or Not Two Bee
 Name That Bee
 Bee The PCBee
 Show Me The Bee!
 The Lora & Husky Show
 Image Conversion to Integer Array for LCD Display
 LoRa Transmission of Images
 Save The Bees Wrap Up - Blog 9
 Save The Bees - Design Challenge
  • robogary
    robogary over 3 years ago
    Congrats on finding the HuskyLens. I tend to get stuck on trying to reinvent things from scratch. The Huskylens seems to be a big step up from the PixyCam and less expensive. How does it perform real time ? Do you anticipate the same time invested on your part in NiclaVision to load & train the ML  as with the HuskyLens ?
    dougw over 3 years ago in reply to robogary
    I expect NiclaVision to be a much steeper learning curve for me. HuskyLens has made the process really simple with automated dataset collection and no programming required to do object recognition/classification. There will still be programming involved to make use of the recognition results, but that is unavoidable. So far I am impressed with real time performance, it is perfect for this application.
