Sci Fi Your Pi
  • Sci Fi Your Pi
Sci Fi Your Pi
Blog QuadCOP:  Post Challenge Update
  • Author Author: screamingtiger
  • Date Created: 15 Sep 2015 4:33 AM Date Created
  • Views 1373 views
  • quadcop_project
  • design_challenge
  • sci_fi_your_pi
screamingtiger
screamingtiger
15 Sep 2015
My QuadCOP is fully repaired.  However there is appears to be one casualty, the Pi-Cam.
I am getting the infamous pi-cam error and all the normal workarounds are failing for me.  When the QuadCop "landed", the little eye/bubble on the head filled with water since it landed in a puddle.  Apparently sound sensors don't detect water real well.  I am not sure if that killed the cam or if the jolt from the ribbon being pulled out did.  I confirmed the ribbon is ok.  The little brown cable from the black camera you can see in the pic, I get the same error if I unplug it so I think the camera itself is shot, but the breakout board is functioning.
I plan to get more flights and continue, but I want to order another Pi Cam to get onboard video.  So stay tuned!  I also need to update my GitHub with some more mods I have been making to try to stabilize it.
    mcb1 over 11 years ago +1
    If I recall correctly the little brown cable has been known to have an intermittant joint.... Mark
  • screamingtiger
    screamingtiger over 11 years ago in reply to mcb1
    I plugged it and unplugged it, no luck!  If you got a fix let me know there are many people who have this issue!
    mcb1 over 11 years ago in reply to screamingtiger
    Sorry that's the limit of my observations around the internet.
    I haven't had any issues myself, but I understand they are static sensitive.
    I also haven't tried deliberately pulling one apart either.
    I presume the white ribbon cable is clean and the marks are in the centre.?
