Sci Fi Your Pi
  • Sci Fi Your Pi
Sci Fi Your Pi
Blog QuadCOP:  Post Challenge Update
  • Author Author: screamingtiger
  • Date Created: 15 Sep 2015 4:33 AM Date Created
  • Views 1373 views
  • quadcop_project
  • design_challenge
  • sci_fi_your_pi
screamingtiger
screamingtiger
15 Sep 2015
My QuadCOP is fully repaired.  However there is appears to be one casualty, the Pi-Cam.
I am getting the infamous pi-cam error and all the normal workarounds are failing for me.  When the QuadCop "landed", the little eye/bubble on the head filled with water since it landed in a puddle.  Apparently sound sensors don't detect water real well.  I am not sure if that killed the cam or if the jolt from the ribbon being pulled out did.  I confirmed the ribbon is ok.  The little brown cable from the black camera you can see in the pic, I get the same error if I unplug it so I think the camera itself is shot, but the breakout board is functioning.
I plan to get more flights and continue, but I want to order another Pi Cam to get onboard video.  So stay tuned!  I also need to update my GitHub with some more mods I have been making to try to stabilize it.
    mcb1 over 11 years ago +1
    If I recall correctly the little brown cable has been known to have an intermittant joint.... Mark
  • screamingtiger
    screamingtiger over 11 years ago in reply to mcb1
    I plugged it and unplugged it, no luck!  If you got a fix let me know there are many people who have this issue!
  • screamingtiger
    mcb1 over 11 years ago in reply to screamingtiger
    Sorry that's the limit of my observations around the internet.
    I haven't had any issues myself, but I understand they are static sensitive.
    I also haven't tried deliberately pulling one apart either.
    I presume the white ribbon cable is clean and the marks are in the centre.?
