Sci Fi Your Pi
  • Sci Fi Your Pi
Sci Fi Your Pi
Blog TrainingSphere - 8 - Frame completed
  • Author Author: amgalbu
  • Date Created: 23 Aug 2015 8:33 AM Date Created
  • Views 2800 views
  • Comments 15 comments
  • sci_fi_your_pi
  • training_sphere
amgalbu
amgalbu
23 Aug 2015
Today I completed the wiring of the TrainingSphere. The final result is shown in picture
As you can see, I finally made the decision the use the Emlib Navio+ board. This is a really challenging project I want to continue to develop even after the end of this design challenge, so I invested some  money in a piece of hardware that is reliable and tested enough to make me develop applications that run in the Raspberry environment and interact with the APM platform. Possibilities are really endless compared with "closed" solutions like pixhawk and ardupilot
Anyway, next steps will include
1. Parameters settings
2. Compass calibration
3. Accelerometer calibration
4. Radio calibration
and finally... first flight (hoepfully)
After that, the plan is the add the optical flow sensor for making the sphere able to loiter in an indoor enviroment
  • fvan
    fvan over 11 years ago +2
    Very tidy, using the spaces in the aluminum frame for cable management is a great idea. It looks very clean!
    balearicdynamics over 11 years ago +1
    Great ! Enrico
    DAB over 11 years ago +1
    Nice build. DAB
  • screamingtiger
    screamingtiger over 11 years ago
    Im curious, maybe I missed it, but what is the Raspberry Pi doing?  I see the Navio connected to it but not sure what function it does.  Thanks!
    balearicdynamics over 11 years ago in reply to screamingtiger
    I suppose that manages the entire system, servos, speeds and all the data excluded by Navio that should be processes, especially the hardware control. Navio itself is controlled by The Raspberry PI. Take a look to this link: http://www.emlid.com
    Enrico
  • screamingtiger
    screamingtiger over 11 years ago in reply to balearicdynamics
    It doesn't manage the servos, the Navio does that, I think its like my setup where the Pi will send the Navio the PWM signals in place of the receiver from the transmitter.  So it will monitor the position and send corrections is my guess.
    I am interested to see how stable the PWM signal will be coming off the Pi.  I use the chipkit pi for this very reason as typically anything PWM needs a real time system.  Hardware based PWM cannot be used since the range is too small.
    I am using the Pi to read 2 PWM channels but I don't need precise resolution, the PWM just goes from the Min to Max with a switch on my radio, so the chance of a "delay" from the OS shouldn't be more than a millisecond, if it is I have an issue!  Most delays I have seen are in the microsecond range, but this will cause issues trying to hold a servo at a precise location.
    Interested!
  • screamingtiger
    screamingtiger over 11 years ago in reply to screamingtiger
    BTW cool frame, and I LOVE this concept of the training sphere.  I had considered it.
    It is true, Joey, I have included the servos and motors but this is - together with the GPS if I am not wrong - a part managed by the Navio board. Interesting your question about the PWM indeed. I remember you come crazy (and me too) connecting the ChipKit PI to the PI image
    Enrico
    Enrico
