Sci-Pi Design Challenge
  • Sci-Pi Design Challenge
Blog Measuring air quality with Raspberry Pi #3 - PCB
Join Sci-Pi Design Challenge to participate - click to join for free!
  • Author Author: deimosmuc
  • Date Created: 3 Jun 2023 3:49 PM Date Created
  • Views 1951 views
  • eagle
  • sensirion
  • air quality
  • pcb
  • sps30
  • hat
  • sci-pi design challenge
deimosmuc
deimosmuc
3 Jun 2023
Theoretically, you could connect the SPS30 sensor to the IO header of the Raspberry Pi without an interface board, provided that you use the UART interface and find a fully assembled cable (on my cable only the JST connector was connected, the other side was open).
Also, most Raspberry Pi-compatible Python drivers I found for the SPS30 use the I2C interface. I2C has the slight disadvantage that we have to add a total of two pullup resistors to 3.3V in the signal path.
Therefore I decided to design an Interface HAT PCB from the Sensor SPS30 to the Raspberry Pi  IO header.
To be as flexible as possible, I also made the UART interface accessible in the PCB design in addition to the I2C one, as well as integrated a couple of QWIC connectors to add more Adafruit modules later.
The design is in Eagle format. The Eagle Design Files (*.BRD and .SCH) will be available in the summary Blog Post.
Schematic:
PCB:
  • Raspberry PI HAT dimensions: 65.0 x 56.5mm
  • 2 Layer Design, FR4 material, 1.6mm thick
  • solder mask colour: nice purple colour (Eagle shows a green solder mask)
  • manufacturing: by JLCPCB.com. 5 pcs. are only 2 USD plus shipping and tax/duties
In the next article, we will put everything together and measure live values from my garden - Link
    genebren over 3 years ago
    I don't know how much help this may be to you, but I roadtested the Panasonic SN-GCJA5 particle sensor last year (along with a couple of other members).  Here is a link to my roadtest review (  /products/roadtest/rv/roadtest_reviews/1558/particulatesmoke_dat  ) .  I know these are similar devices, but the interfaces are different.  If you have issues or questions that I might be able to help you with please don't hesitate to ask.  Best of luck on your project.
    Nice looking board!
    Nice looking board!
