Smarter Life
  • Smarter Life
Smarter Life
Blog A Very Compact Christmas Display - Part 045
  • Author Author: COMPACT
  • Date Created: 5 Jan 2014 4:36 AM Date Created
  • Views 1827 views
  • Comments 11 comments
  • psoc4
  • psoc_4
  • smarter_life_challenge
  • psoc_4200
  • compact_xmas_display
  • ws2811
  • smarter_life
  • camera
  • psoc
COMPACT
COMPACT
5 Jan 2014
A Floral Bokeh
Here is a picture of the Ring with white selected.
The following are self portraits done using the Light Ring without the flash enabled and with the camera hand held.
With the first attempt you can see the reflection from the Light Ring.
With the second and third attempts I have bokeh. http://en.wikipedia.org/wiki/Bokeh
Deliberate and artistic bluring (Well not really.)
I now need to invest in a decent Macro Lens or adapter and make a diffuser for the Light Ring for better close ups.
    mcb1 over 12 years ago in reply to DAB +1
    DAB You are right, and I used to think that lens worked well from their lowest to their highest aperture until I read this. http://www.kenrockwell.com/nikon/50-comparison/f-stops.htm He has some other…
    Compact
    Reflections are always the issue, and controlling them is the biggest problem I've had.
    You might want to look at extension rings for your existing lens.
    If your existing lens is fully electronic, then finding a manual lens is the answer.
    After that a good tripod and F16 or F22 is your friend.
    You can also do focus stacking which I understand works well, but I haven't needed to use it ...yet.
