Smarter Life
  • Smarter Life
Smarter Life
Blog PSoC 4 Tricopter (Smarter Life Challenge) part #12
  • Author Author: yuritikhonov
  • Date Created: 11 Jan 2014 8:00 PM Date Created
  • Views 1742 views
  • Comments 6 comments
  • RoadTest
  • tricopter
  • psoc4
  • Multiwii
  • smarter_life_challenge
  • smarter_life
  • smart_tricopter
  • smart_control_and_diagnostics
  • quadcopter
yuritikhonov
yuritikhonov
11 Jan 2014
If you like my project vote for "A Smarter Tricopter - Yuri Tikhonov" image
Good day comrades!
1. Earlier this week, I was doing final preparations for the tricopter's flight. TODO list included:
  1. Firmware: many small but critical changes;
  2. Rx: completion of wiring;
  3. Tx: battery replacement;
  4. PCB: repair of a defective LED;
  5. PCB:  soldering of supply conductive tracks;
  6. ESC: brakes off, "Quick Start" on, etc..;
  7. ESC/BLDC: three-phase wiring soldering;
  8. ESC/LiPo: checking all units of the power supply;
  9. LiPo: battery charging;
  10. Props: balancing;
  11. Frame: balancing, broaching  of all nuts;
  12. YAW:  reinforcement of servo mounting;
  13. YAW: inserting of wooden components for increased rigidity;
  14. YAW: decrease of backlash and lubrication of mechanism;
  15. YAW: servo rod reinforcement;
  16. YAW/firmware: setting of limiting deflection angles of YAW;
  17. Other: preparation of a complete set of tools and parts for outdoor testing.
Precautions were justified: the servo was very poorly secured, and one of the power wires just fell off!
After the elimination of all malfunctions, we were ready for the first flight test.
2. So epic moment: 10.Jan.2014, 4:00PM
we went to search the site. The nearest of suitable, was an empty arking. Ready, Steady, Go!
Mass of the device - approximately 800 grams.
According to calculations, the device should hang at throttle = 50%:
When conducting flight  the throttle lays in the range of 30-50% because I was afraid to raise apparatus higher than 2 meters. In case of a skilled pilot (which I am not) and good weather conditions, the device can easily go up, performing tricks at a great speed!
3. But back to reality image The flight was greatly interfered with the wind, and given the fact that the ground on which the tests were conducted was lined with concrete tiles, when planting we broke one of the landing legs. Using plastic ties, the problem was quickly solved! In the end, after the first tests the copter received the damage of about 30 cents image If I did not observe precautions and conducted the first flight test at home (with faulty wiring, etc.), I'm sure - copter would be completely destroyed!
During the tests, in addition to weak legs, were found the following shortcomings:
  • Pilot (i.e. I) requires long training, both on the real machine and simulator image
  • PID settings of accelerometer needs tuning (so the flight was conducted in "Acro Mode").
  • Data stored in EEPROM for some reason sometimes disappear. For tests we took with us a laptop and an USB-UART Converter, so that the EEPROM did not hinder our testing.
  • The power connector is in a wrong position, it is very inconvenient to disconnect it from LiPo, for this we have to make great efforts. Though it is a small thing, but apparently it was the reason of breakage of a wire last week!
4. So, the first flight trials can be considered a success! Maybe it's the world's first working prototype of threecopter on the basis of PSoC 4 image
As I promised, I put the firmware in the open access (for non-commercial purposes), so that each interested person could try to build one's own three or quadrocopter on the basis of our beloved PSoC 4!
Friends, thank you for your support and interest in the project. These eleven weeks will forever remain in my memory, and the tricopter will have pride of place in my collection. Sad to say goodbye, but this post is the last of the cycle "PSoC 4 Tricopter: Smart Life Challenge", I hope you were just fun to read my posts, as I was curious to build this unit.
After a while I will certainly continue to work on tricopter, I already have a lot of great ideas here! Goodbye comrades!
#linkdescription
1PSoC 4 Tricopter Part #1Introduction
2PSoC 4 Tricopter Part #2Purchase of components from Farnell and HobbyKing
3PSoC 4 Tricopter Part #3PSoC firmware: upTime & Rx
4PSoC 4 Tricopter Part #4PSoC firmware: UART & MultiWii GUI
5PSoC 4 Tricopter Part #5PSoC firmware: EEPROM emulation
6PSoC 4 Tricopter Part #6PSoC firmware: Servo & ESC control
7PSoC 4 Tricopter Part #7PSoC firmware: IMU, LED's & PID
8PSoC 4 Tricopter Part #8Hardware: PCB
9PSoC 4 Tricopter Part #9Hardware: tricopter's frame
10PSoC 4 Tricopter Part #10Hardware: YAW mechanics & motors
11PSoC 4 Tricopter Part #11Hardware: ESC's, wires & misc
12PSoC 4 Tricopter Part #12Final: The first fly
PSoC4_Tricopter_Firmware.zip
    DAB over 12 years ago +1
    Well done Yuri, Loved the video and am a big Wagner fan, so I was thoroughly pleased with the flight. You did much better on the first flight than I did with my recent copter flight attempt, but as you…
    DAB over 12 years ago in reply to yuritikhonov +1
    Hi Yuri, No posts. I just picked up an inexpensive copter kit that was on clearance sale. I did not have any specific purpose in mind, it just looked like something I could use to tease my little Jack…
  • vsluiter
    vsluiter over 12 years ago +1
    Yuri, I hereby assign to you the rank of 'PSOC4-Tricopter Pilot Commandor Builder Chief' Very nice work, I'm so happy for you that you did get the parts in time from HobbyKing, and that you even made it…
  • yuritikhonov
    yuritikhonov over 12 years ago in reply to vsluiter
    I'm glad to serve for the benefit of aviation sir! image
    The best thing in this story is that the tricopter is still alive and ready to surf the sky! image
  • vsluiter
    Yuri,
    I hereby assign to you the rank of 'PSOC4-Tricopter Pilot Commandor Builder Chief' image
    Very nice work, I'm so happy for you that you did get the parts in time from HobbyKing, and that you even made it to fly the tricopter around before the end of the challenge! Superb work! It's taken some preparation, but now you're where you wanted to be!
  • yuritikhonov
    yuritikhonov over 12 years ago in reply to DAB
    Wow! Interesting story DAB! I understand you: landing is a one of the most difficult tasks. Some times ago I was fully disintegrated one of my helicopters after landing "on sideway". And the cost of the repair is more than the cost of the kit (without electronics). Bot for now I have the opportunity to remake the helicopter as I like (with custom swash plate and other components) image
    Hi Yuri,
    I did not have any specific purpose in mind, it just looked like something I could use to tease my little Jack Russell Terrier with.  She viciously attacked my RC car.  She tears the tires off of it and keeps attacking if I just twitch the wheels a little so she thinks its alive.
    So far all I have done is bop her nose as it fell from the sky due to my poor piloting skills.
  • yuritikhonov
    Thank you very much DUB!
    You are right, I need more practice because it is my first outdoor multicopter. But after look at raw video from cellphone I found strange roll and pitch deviation, but I do not see yaw deviation. Answer is a very simple: in yaw I use only "P" controller but in roll and pitch I use "PID" with big "I" and "D". I think integration part of the roll and pitch is a reason of the deviations.
    P.S. DUB, do you have any posts or articles about your aircraft hobby? It is a very interesting to see another works!
