Smarter Life
  • Smarter Life
Smarter Life
Blog Smart solder reflow oven exterior
  • Author Author: Kilohercas
  • Date Created: 30 Jan 2014 4:05 PM Date Created
  • Views 2423 views
  • Comments 10 comments
  • smarter_life
  • reflow_oven
Kilohercas
Kilohercas
30 Jan 2014
2 days work on exterior and today i can say, it turns out better than i expected . Now only UI programming is left, RTC, PID,PWM are working and i can do reflow soldering even today, but i need to make clean UI.
Still don't know how can this project be completely ignored by in this contest, but where is other contest on STM32F429 that needs to explore DMA2D peripheral and what is exactly what i need for my user interface, alpha blending for 2 temperature graphics, also transparency for on screen keyboard and so on.( but i am running low on SRAM, so it could be a challenge )
    DAB over 12 years ago in reply to Kilohercas
    Hi Linus,
    Think about using sprites.  They are very low on memory use and you can set them up with counters to paint them at the right location on the screen.
    Good resolution displays are both a blessing and a curse.  I used an 8085 to drive a 400 by 400 pixel display back in the early 1980's.  We used a memory board with one bit display resolution for each pixel and then just dumped the array to the display.  Crude but it worked for real time updates.
  • Kilohercas
    Kilohercas over 12 years ago in reply to DAB
    problem is not that i don't know how to program, problem is i am low on resources. Now look, it is easy to make mathlab program, calculate matrix multiplication and so on. but it consumes lot of memorycare, i can make 6GB dynamic array on my notebook, without any problem . Because i have huge screen, (800x480) i need lot of resources to make it work,since only DMA send around 0.786MB/frame at 60FPS. At the same time i have to change GRAM buffer data, that cause tearing and all other visual problems. Not only that i have problems with flash loader, half of STM32F429 memory is damaged somehow... so only uploading 400x400 picture will cause flash loader crash image
    We learn by doing.
    Look upon it as an opportunity to explore new territory.
    Sit down and plan out what you want to do and define a control sequence that is simple and easy to follow.
    Then you just draft out the command/control structure and identify the information you need at each step.
    That way you can keep the flow simple and easy to program.
  • Kilohercas
    intel inside, idiot outside , so no, it will take lot of time to do that. and i am not good at programming
    Hi Linus,
    Good looking build.
    You should be able to make a nice usable UI with the tools you have.
