From the manual,
The TMC5272-EVAL has the option to use two power inputs. You need to use both if you want to use the TMC5272 at low voltages. This is necessary as the Landungsbruecke needs a minimum voltage of 8 V via the Eselsbruecke connector to operate correctly.
