Summer of Green Tech Design Challenge
  • Summer of Green Tech Design Challenge
Blog Climate Change Monitoring System and Soil Contours to Increase Agricultural Efficiency #5 - Physical Build Process
Join Summer of Green Tech Design Challenge to participate - click to join for free!
  • Author Author: Zhar_14
  • Date Created: 16 Oct 2023 4:29 AM Date Created
  • Views 1042 views
  • summer of green tech design challenge
  • seeedstudio
  • Xiao
Zhar_14
Zhar_14
16 Oct 2023
Hello Guys, I will share my experience in the hardware and case assembly process for the Climate Change Monitoring System. To create a 3D design of the casing, I used Tinkercad software
tk
Before printing, I used the Ultimaker Cura slicer software to change the 3D STL format to G-Code.
cr
Next is the printing process using a 3D printer. With filament PLA+
pr
After everything is finished, proceed to the assembly stage between the case and the electronic system that was created in the previous post.
          1.Assembly of the second node as a receiver
n1
At the first node, the power source comes from a 1000Mah capacity battery, equipped with a 1A lithium charger, namely TP4056.
            2. Next is the stage of assembling the first node
ds
In the picture above, I placed the XIAO SAMD21 on the back of the PCB and Lora E32 On the Bottom of the PCB. here are the assembly results of the first node:
2
The first node uses resources from a 10Wp 12V Solar Panel, reduced using a Mini MPPT to 5V with a maximum electric current of 5A, then the power from the MPPT will be stored in a battery with a capacity of 6000Mah.
dh
(DHT 20 Sensor)
ha
(Hall Effect Sensor to read rainfall)
hk
(Overall Results after assembly)
There are two elements of green technology in this innovation, as follows:
  • The electrical resources used come from renewable energy, namely Solar Panels with a capacity of 12V/10Wp.
  • The casing used is made from environmentally friendly PLA+.
That's the process of assembling the Climate Change Monitoring System, thank you for reading my blog, next I will post testing of this innovation on coffee plantations.
    dougw over 2 years ago
    Looking good.....Thumbsup
  • Zhar_14
    Zhar_14 over 2 years ago in reply to dougw
    Thank You Slight smile
  • Zhar_14
