Sustain The World - Design Challenge
  • Sustain The World - Design Challenge
Documents Infineon - Technical Support Thread
  • Author Author: e14phil
  • Date Created: 18 Aug 2020 3:44 PM Date Created
  • Last Updated Last Updated: 6 Oct 2021 10:26 PM
  • Views 2633 views
  • Comments 21 comments
Hello everyone,
I created this thread here for technical support regarding Infineon hardware for the element14 sustain the world challenge.
Please post all questions here, if you got issues and problems.
However, part of the challenge is also to come along with the hardware by yourself! To don't get overwhelmed by too many questions,
I want to encourage you all, that you are trying to solve small problems as well as possible by yourself first! image
Furthermore, even though it's a competitive challenge, helping each other is also possible and welcome!
jd_tech_support_ifx and me will try to answer your questions!
Good luck to everyone!
Mr. Brew
This document was generated from the following discussion: Infineon - Technical Support Thread
  • wanfp97
    wanfp97 over 6 years ago +2
    Thanks, rati89 and jd_tech_support_ifx , you guys are really amazing and helped me a lot. Without you guys, I might even use up much more time figuring out about the kit. Thank you very much. Sincerely…
  • e14phil
    e14phil over 6 years ago +1
    Thank you : rati89 jd_tech_support_ifx
  • wanfp97
    wanfp97 over 6 years ago +1
    Hi, Do anyone have successfully control the DC Motor shield using XMC4700 programmed by DAVE? I can control it using example code in Arduino IDE, but there Arduino can only have 2 interrupt pins. And I…
  • cyberwizard
    cyberwizard over 6 years ago
    hello,
    i have a sim900a and I want to know what corresponding DAVE apps are used for serial communication for texting.
  • wanfp97
    wanfp97 over 6 years ago in reply to jd_tech_support_ifx
    Hi JD,
    Below is my email address:
    wanfp97@gmail.com
    Thanks for helping me out.
    Sincerely,
    FP
  • jd_tech_support_ifx
    jd_tech_support_ifx over 6 years ago in reply to wanfp97
    Hey Fook Peng,
    I have good news. The colleague from the other department sent me some example code.
    Can you give me an email address? Or is there a possibility to attach something that I don't see ...
    Because then I can share the files with you.
    BR,
    JD
  • wanfp97
    Thanks JD. I will wait for your good news.
    BR,
    FP
    Yes sorry Fook Peng, that's what my colleague told me as well. I wasn't aware that we support that in DAVE. Since I'm not an expert in DAVE I guess I'm not the right person to help you here. But I will forward your concern to someone who is maybe able to help. I will let you know!
    BR,
    JD
  • wanfp97
    Thanks JD. I do notice that freeRTOS for XMC4700 is available in DAVE, but the problem is I don't know how to control the DC Motor shield in DAVE. Can you teach me how to do that? Thanks in advance.
    Best Regards,
    Wan Fook Peng
    Hey Fook Peng,
    which kind of RTOS?
    I know that we have example for the XMC1100 Bootkit and freeRTOS, take a look here (for DAVE):
    https://www.infineon.com/cms/en/product/promopages/aim-mc/dave_downloads.html
    Just write "freeRTOS" in keyword-filter.
    And I think a few other platforms are supported as well for freeRTOS, see here:
    https://www.freertos.org/a00090.html#INFINEON
    But I think for the XMC4700 we don't have a example, but I asked a colleague already and will let you know if I'm wrong.
    BR,
    JD
  • wanfp97
    Hi,
    Do anyone have successfully control the DC Motor shield using XMC4700 programmed by DAVE? I can control it using example code in Arduino IDE, but there Arduino can only have 2 interrupt pins. And I also couldn't find Free RTOS library for XMC4700 in Arduino IDE. It would be great if someone can teach me to do it in DAVE. Thanks in advance.
    Sincerely,
    Fook Peng
  • wanfp97
    Hi Mr Brew and Dominik,
    Do XMC4700 supports RTOS?
  • wanfp97
    Thanks, rati89 and jd_tech_support_ifx, you guys are really amazing and helped me a lot. Without you guys, I might even use up much more time figuring out about the kit. Thank you very much.
    Sincerely,
    Fook Peng
