Sustain The World - Design Challenge
  • Sustain The World - Design Challenge
Documents Infineon - Technical Support Thread
  • Author Author: e14phil
  • Date Created: 18 Aug 2020 3:44 PM Date Created
  • Last Updated Last Updated: 6 Oct 2021 10:26 PM
  • Views 2634 views
  • Comments 21 comments
Hello everyone,
I created this thread here for technical support regarding Infineon hardware for the element14 sustain the world challenge.
Please post all questions here, if you got issues and problems.
However, part of the challenge is also to come along with the hardware by yourself! To don't get overwhelmed by too many questions,
I want to encourage you all, that you are trying to solve small problems as well as possible by yourself first! image
Furthermore, even though it's a competitive challenge, helping each other is also possible and welcome!
jd_tech_support_ifx and me will try to answer your questions!
Good luck to everyone!
Mr. Brew
This document was generated from the following discussion: Infineon - Technical Support Thread
  • wanfp97
    wanfp97 over 6 years ago +2
    Thanks, rati89 and jd_tech_support_ifx , you guys are really amazing and helped me a lot. Without you guys, I might even use up much more time figuring out about the kit. Thank you very much. Sincerely…
  • e14phil
    e14phil over 6 years ago +1
    Thank you : rati89 jd_tech_support_ifx
  • wanfp97
    wanfp97 over 6 years ago +1
    Hi, Do anyone have successfully control the DC Motor shield using XMC4700 programmed by DAVE? I can control it using example code in Arduino IDE, but there Arduino can only have 2 interrupt pins. And I…
  • e14phil
    Thank you :
    rati89
    jd_tech_support_ifx
