Twist, Turn and Move Design Challenge with TE Robotics
  • Twist, Turn and Move Design Challenge with TE Robotics
Documents Twist and Turn Design Challenge - Meet the Challengers
  • Author Author: e14phil
  • Date Created: 7 Jul 2022 2:36 PM Date Created
  • Last Updated Last Updated: 11 Jul 2022 3:27 PM
  • Views 5991 views
  • Likes 9 likes
  • Comments 38 comments
design challenge profile
The Twist, Turn, and Move Robotics Challenge
The Challengers | About This Challenge | Dates | The Judges | The Kit | The Prizes | Example Application | Terms & Conditions
Join us in Congratulating the Official Challengers of the Twist, Turn, & Move Design Challenge:
Internet Controlled Teleoperation Robot
nilutpol_kashyap
Unlimited CNC Robot
dwinhold
The Robo Cat
jwr50
Pool Butler
robogary
ARDUMOBO: Arduino mobile robot
a33333
PV Cleaning System
amgalbu
Robotic Yoga Instructor
hitesh.boghani
Sammy Semaphore - Semaphore Robot
dougw
R-Arm
GustavoMorales
Autonomous Navigation Robot
ajayvishaal
The Dates
To make sure challengers get their kit on time we have pushed back the end dates of this challenge and will be updating the site copy and terms to correspond with this.
Project Phases Dates
Challengers Announced 6th July 2022
Build Period 7th July - 12th September 2022
Projects Due 12nd September 2022
Winners Announced September 2022
Prizes Shipped September 2022
The Challenge
Each participant will receive a Challenger’s Kit, with which they are challenged to design and build a robotic arm or mobile robot that performs a specific task.
These 10 successful applicants will get a Selection of TE Connectors, an Arduino Uno, and Robotics Shields, free of charge, to build and blog their project with.
For the chance to win one of the prizes below, participants must blog their build process, as well as the final outcome of their Robotic Movement Project.
Included in the Challenger's Kit are a Selection of TE-provided components, as well as an Arduino Uno; use these to create your Robotic Movement Project.
Good integration of the TE components and interesting uses of movement will be graded more favorably.
Example tasks that can be performed include, but are not limited to:
  • Building a robot arm that can pick up and set down an object
  • Building a robot arm that moves in all degrees of freedom
  • Building a mobile robot that follows a line
  • Building a mobile robot that can avoid an object in its path
Challenger's Kit The Kit Product Name
connectors kit
TE Connectors Kit
(Product Image may differ)
Dynamic Connectors Parts:
1-2366515-4 Connector Housing
2367817-2 Contact
2-2366515-4 Connector Housing
1-2366600-4 Connector Housing
2367819-2 Contact
2-2366600-4 Connector Housing
1891526-1 Extraction Tool
1-2366515-8 Connector Housing
2-2366515-8 Connector Housing
1-2366600-8 Connector Housing
2-2366600-8 Connector Housing
More Items:
AXICOM IM Signal Relay
M4473 SL005 Multipair Cable
Circular Plastic Connector Series 1
Circular Connector Size 11
M8 Series Connector Male
M8 Series Connector Female
D-Sub Connector
D-Sub Connector
201328-1 Multimate Contact Type II
201330-1 Contact
Wired-Board Connector
Receptacle FFC/FPC Connector
Pin Header
connectors kit
Arduino Uno
Buy Now
connectors kit
DRI0017 2x2A Motor Shield for Arduino Twin (Product Image may differ)
connectors kit
DFR0502 Gravity: IO Expansion & Motor Driver Shield (Product Image may differ)
The Prizes
Prize Prize Category
Grand Prize
Approximate Value $2100 USD*
  • Flash Forge Guider II 3D Printer
  • iRobot Roomba Self Emptying Robot Vacuum Clearer
Runner Up
Approximate Value $500 USD*
  • iRobot Bravaa Jet Robot Mop
  • Ender 3 V2 3D Printer
Finisher Prize**
To be a finisher you must complete 5 blogs and show us your testing the resilience of the project.
Approximate Value $30 USD*
  • Multicomp Pro Multimeter
*Or local equivalent
**Grand Prize and Runner Up winners also earn the finisher prize.
  • jwr50
    jwr50 over 4 years ago
    I'm listed as a challenger, but I haven't received a confirmation email.  I see other competitors have already received their parts kits.
  • e14phil
    e14phil over 4 years ago in reply to jwr50
    Hey Jwr50 ill investigate this for you now, thanks for reaching out!
  • e14phil
