Ultimate RoadTest
  • Ultimate RoadTest
Ultimate RoadTest
Blog Project "code name" Part 003
  • Author Author: COMPACT
  • Date Created: 25 Apr 2012 12:00 AM Date Created
  • Views 1041 views
  • ultimate_roadtest
COMPACT
COMPACT
25 Apr 2012
25th April 2012
"A Minor(ity) Report"
I have been working on an interface board between the SimpleLink WiFi CC3000/Fraunchpad technology (SWiFT for short) combination and existing appliances to enable them to be remotely controlled.
To do this, where possible I will retain the appliances' original functionality and Internet enable them.
This has been accomplished my second appliance which currently is under wraps until I'm ready to present it.
It operates normally but also but can also be controlled by SWiFT.
This picture may or may not give you a hint.
(Another hint: It's not all my crappy soldering being displayed here.)
This brings me mention two important clarifications:
     1. "A Soldering Iron is not a diagnostic or test tool!"
     2. "Electricity doesn't judge a solder joint's connectivity by the way it looks."
The appliance has been reverse engineered to the degree where appropriate tap points are identified (in the identical fashion that I used for the Nokia 5110 phone).
I've also used an isolation strategy ensuring that the appliance remains electrically isolated from SWiFT.
This is not just for my safety but it also minimises the risk of blowing up my one and only Fraunchpad.
  • COMPACT
    COMPACT over 14 years ago
    Thanks DAB,
    As Obi Wan said.
    "Your eyes can deceive you. Don't trust them. Use a continuity meter."
    This is particularly true with modern day Lead free solders.  In fact, these Lead free solders can have the opposite problem and can grow whiskers that create unwanted short circuits over time.
    Cheers
    Very Compact
  • COMPACT
    Thanks DAB,
    As Obi Wan said.
    Cheers
    Very Compact
