Ultimate RoadTest
  • Ultimate RoadTest
Ultimate RoadTest
Blog Project "code name" Part 009
  • Author Author: COMPACT
  • Date Created: 12 May 2012 2:59 AM Date Created
  • Views 1049 views
  • ultimate_roadtest
COMPACT
COMPACT
12 May 2012
12th May
Sound Advice
Here is the PCB just off the mill.
It hosts the DAC, sound buffer and output buffer.
The output buffer is just an LM358 OP amp to protect the DAC. It is configured for unity gain.
Here is a dry fitting of the adapter PCBs and connectors.
CAD makes things so easy to line up!
  • COMPACT
    COMPACT over 14 years ago
    Hi DAB,
    Thanks for tehe comments.
    I make all of my own prototype PCBs because this accelerates the development process.
    I can make both single and doubled sided PCBs.
    For this project I am driving a speaker.
    In this case the DAC is generating a standard 1v peak to peak audio signal.
    Cheers
    Very Compact
    DAB over 14 years ago in reply to COMPACT
    Hi very compact,
    I am impressed with the quality of your boards.  I am sure that others would like to hear about the process you use.  After the contest of course. image
    Back to the DAC, are you going to use an impedance matching circuit or are you just planning to drive the speaker directly?
    Just curious,
    Hi very compact,
    Just curious,
