Ultimate RoadTest
  • Ultimate RoadTest
Ultimate RoadTest
Blog Project "code name" Part 009
  • Author Author: COMPACT
  • Date Created: 12 May 2012 2:59 AM Date Created
  • Views 1047 views
  • ultimate_roadtest
COMPACT
COMPACT
12 May 2012
12th May
Sound Advice
Here is the PCB just off the mill.
It hosts the DAC, sound buffer and output buffer.
The output buffer is just an LM358 OP amp to protect the DAC. It is configured for unity gain.
Here is a dry fitting of the adapter PCBs and connectors.
CAD makes things so easy to line up!
    DAB over 14 years ago
    Good job on the board.  Did you make it yourself or have it done?
    Are you planning to drive a speaker or transducer?
    I like the idea of mounting SMD's onto mini boards and then placing them on pins.  It's a very useful technique for mounting modern chips so you can plug them into TTL sockets.
    Good update,
    Good update,
