Upcycle IoT Design Challenge
  • Upcycle IoT Design Challenge
Blog Food Waste: Case
Join Upcycle IoT Design Challenge to participate - click to join for free!
  • Author Author: Zhar_14
  • Date Created: 1 Jan 2024 5:20 PM Date Created
  • Views 561 views
  • food waste
Food Waste: Case
Zhar_14
Zhar_14
1 Jan 2024
PCB waste often contains dangerous materials such as lead, cadmium, mercury, and other chemicals, which can pollute the environment if not managed properly. PCB waste management is important. That's why I try to recycle PCBs by making cases from PCBs!
Here are the steps for making a case from a PCB:
  • PCB Selection
For PCB selection, I chose PCBs that can be recycled because some PCBs are fragile, so I have to be more selective in choosing PCBs for the next component desoldering process.
1
  • Cutting
    In this process, the PCB that has been selected is immediately cut according to the specified size. Here, I cut it using a hacksaw. You can see it in the picture below:
2
  • Refinement
Next, the PCB that has been cut will be smoothed using sandpaper because the results of the cutting sometimes have sharp and uneven edges. Here is the smoothing process:
3
  • Gluing
To make the case frame, I used glue on the ends of the PCB and arranged them to form a suitable case. Here are the results:
4
Results:
5
It can be concluded that to make a case from this project, four stages are required, namely selecting, cutting, smoothing, and gluing. In the next blog, I will discuss the hardware assembly process for this project.
    DAB over 2 years ago
    Interesting idea.
    I have a lot of very old PCBs that could make interesting containers.
    Interesting idea.
  • Zhar_14
    Zhar_14 over 2 years ago in reply to DAB
    Sure, you can make containers from used PCBs.
