Upcycle IoT Design Challenge
  • Upcycle IoT Design Challenge
Blog PC Power Supply - Upcycle & Repurpose
Join Upcycle IoT Design Challenge to participate - click to join for free!
  • Author Author: dougw
  • Date Created: 13 Jan 2024 6:09 PM Date Created
  • Views 5822 views
  • Likes 14 likes
  • PC bench supply
dougw
dougw
13 Jan 2024
Intro
This section of the Upcycle Design Challenge is about upcycling and repurposing a PC power supply. Specifically I want to turn the power supply from an obsolete PC into a useful bench power supply, complete with meters and binding post banana jacks.
This is my 5th blog in this design challenge and I haven't even done an unboxing blog - because the challenge kit has not arrived yet. Fortunately these sections don't need the kit components.
The Teardown
The PC chassis is too big to use as a power supply chassis, so I wanted to explore hacking the chassis down to a reasonable size while retaining the power supply mounts. This is a video of the attempt...
This work shows what I was trying to do and that it is likely feasible, but it was turning out to be problematic to make the result look like a polished instrument, so I changed to a different approach. This new approach uses more 3D printed parts to make things fit nicely.
PC Bench Supply Build
Discussion
Converting a PC power supply into a bench power supply turned out to be much more work than I had expected. Doing metal work without the right tools and skill set pretty much explain why I spent so much time, but I definitely gained an appreciation of what it takes to work with sheet metal. Ultimately I opted to 3D print some of the parts, to make sure the finished instrument would be presentable. The new approach still took a significant amount of work, but it turned out well. The final power supply features 6 USB charging ports, 3 volt meters and 3 ammeters in addition to the traditional banana jack binding posts. I am happy with the supply, it will find uses when I need computer voltages with significant current.
Links:
Upcycle The Beast - Blog 1
Serendipitous Salvage - Blog 2
What is on those old disks?
Mr. Pentium
PC based bench supply
Previous PC Power Supply Conversion
Curiosity Nano Unboxing
 Curiosity Nano Programming
 Super-cycle Design Challenge
Upcycle IoT Design Challenge Info
  • michaelkellett
    michaelkellett over 2 years ago
    Hello Doug,
    Not that surprised you had so much trouble trying to re-work sheet metal - a really tricky task but you gave it a good go !
    I'm never sure where one would use a PC supply based bench PSU - the lack of fast acting and adjustable current limiting coupled with the ability to spit out a few hundred watts at 12V makes them a bit risky for most development work.
    It's a shame because I have a considerable number of old PCs and I'll end up paying to get rid of them !
    MK
  • michaelkellett
    Hello Doug,
    MK
    dougw over 2 years ago in reply to michaelkellett
    Yes, they are not to be confused with a decent bench supply that has good performance and protection. Just handy if you need some power and understand the limitations. I might do some noise measurements just to see how clean it is or isn't.
