Upcycle IoT Design Challenge
  • Upcycle IoT Design Challenge
Blog Upcycle the Beast
Join Upcycle IoT Design Challenge to participate - click to join for free!
  • Author Author: dougw
  • Date Created: 25 Nov 2023 11:21 PM Date Created
  • Views 4140 views
  • Likes 16 likes
  • Comments 9 comments
  • FabGL
  • space invaders
  • altair 8800
  • VIC 20
Upcycle the Beast
dougw
dougw
25 Nov 2023
Intro
This is the first blog in the Upcycle IoT Design Challenge. My project will explore some unique ways to upcycle, recycle, reuse, upgrade, modify, hack, recreate and reimagine a 24 year old PC. The parts kit for the challenge have not arrived, but there are lots of things I can do before the kit arrives.
Here is a quick video intro...
Reuse the Peripherals
Before I even get into disassembly, I want to explore reusing the peripherals that are still perfectly functional and in fact still have merit.
The first reuse application is to recreate a CP/M computer - because I always wanted one but could not afford $2,000 back in 1978 (equivalent to $10,000 today)
CP/M Computer
Commodore VIC 20 Emulator
The next retro computer I want to explore is a Commodore VIC 20 from around 1981...
The final retro application for this blog will be a Space Invaders game...
Space Invaders
ESP32 Enclosure
Here is a video showing the 3D printed enclosure...
FabGL
These emulations use FabGL - here is a brief explanation of how to load FabGL onto an ESP32...
FabGL Schematic
Here is a link to the generic FabGL schematic in case you want to roll your own ESP32 VGA module:
imagehttp://www.fabglib.org/schema.png
Conclusions & Discussion
So Far this project is already a blast exploring some nostalgic computer systems and software. These particular emulations have special meaning to me and I am thrilled to be able to implement them all with a $20 module. If any readers out there are also nostalgic for the old VIC20 days, they can also enjoy exploring the old software with this inexpensive platform.
I have ordered some more parts for other aspects of this project, but some have not arrived, and of course the Microchip SAM E51 Curiosity Nano Evaluation Kit has not arrived either. It will be used to augment my Rockwell AIM65 computer.
STL files
ESP32VGA.zip
Links:
Upcycle The Beast - Blog 1
Serendipitous Salvage - Blog 2
What is on those old disks?
Mr. Pentium
PC based bench supply
Curiosity Nano Unboxing
 Curiosity Nano Programming
 Super-cycle Design Challenge
Upcycle IoT Design Challenge Info
    dougw over 2 years ago in reply to ctigs +1
    ctigs I will add the stl files to the blog above.....done.
    beacon_dave over 2 years ago
    Looks like some retro fun to be had there.
    Do you know if these emulated systems can reliably access serial com ports via the FabGL library ? Either shared with the programming port UART like an Arduino Uno or via a pair of unused GPIO pins, using a MAX232 type line driver ?
    dougw over 2 years ago in reply to beacon_dave
    I don't know the full answer yet.
    One of the examples in FabGL is a full ANSI Terminal but I don't know what interface it uses.
    The generic FabGL schematic does not use the ESP32 UART pins, so they should be available.
    The FabGL CP/M emulator allows the keyboard and display to emulate a selection of terminals, such as DEC VT52, VT100 and Lear Siegler ADM3A.
    The ESP32 itself has 3 UARTS capable of 5 MBaud with full hardware flow control and interrupt operation.
    The VGA module I have doesn't have a UART connector.
    beacon_dave over 2 years ago in reply to dougw
    The FabGL 'Serial Terminal' version of the board has the onboard MAX232 line driver connected to IO2 and IO34
    The programing port is connected to TXD0/IO1 RXD0/IO3 but doesn't have the USB to UART converter on board.
    https://www.tindie.com/products/fabgl/fabgl-serial-terminal-ttl-and-rs232/
    I'm not sure if this is the same expected setup for the CP/M terminal emulator or not.
    The CP/M emulator I have uses the PS2 keyboard and VGA display to emulate a selected terminal type, talking to CP/M.
