Vertical Farming
  • Vertical Farming
Vertical Farming
Blog Automated Green House Blog:20.2 - Toying with Chemical Analysis - pH
  • Author Author: m.ratcliffe
  • Date Created: 2 Nov 2015 10:19 PM Date Created
  • Views 957 views
  • adapted_greenhouse
m.ratcliffe
m.ratcliffe
2 Nov 2015
What is pH
This is a subject my high school teacher quickly covered as:
"It is a logarithmic representation of the concentration of H+ ions
The pH scale measures how acidic or basic a substance is
pH==7  neutral
pH<7  alkaline [basic]
pH>7  acids"
This didnt make sense at the time, a magic concentration of H+ ions [pH7] is neutral but any fewer or any more and it is not neutral, but the reason why this occurs s quite a hard concept to understand, if you want to understand it see reference [1]
Why is pH important in Hydroponics
The availability of chemicals to the roots is heavily dependant on pH[see figure below]. In short, get the pH major wrong and your plant wont be able to use the expensive nutrients in the growing fluid you just made.
[Nutrient availability vs pH,  thicker lines is better][2]
If you have ill plants, pH is a hard one to find as the issue because it will usually appear to be a deficiency of P. making you believe that you need more P [Phosphorous], when in fact you just need to change the PH to make more P available to the plant.
What is the "Best" pH
This is a hard one to  pinpoint, it depends on the types of plants in the system and has to accommodate any other living organisms in the system [fish].
It is commonly quoted that a pH of 5.4 to 6.4 is the best range for most plants [2][3]
That is why we will have a set point of 5.9 for our pH controllers in many hydroponics/aquaponics.
Please do check that your fish are happy with this pH and consider researching the optimum pH for the plants in your system.
References:
[1]Determining and Calculating pH - Chemwiki
[2] Bodie V. Pennis " Essential pH Management in Greenhouse Crops: pH and Plant Nutrition" B 1256
[3]A Publication of the International Plant Nutrition Institute (IPNI) "SOIL PH AND THE AVAILABILITY OF PLANT NUTRIENTS"
    DAB over 10 years ago
    Nice update.
    It is indeed a science to balance the soil composition, PH, salt levels and fluid components for various plants.
    Nice update.
