Vertical Farming
  • Vertical Farming
Vertical Farming
Blog First blog
  • Date Created: 15 Aug 2015 1:04 PM Date Created
  • Views 765 views
  • Comments 6 comments
  • design_challenge
  • vertical_farm
  • vertical_farming
  • iot
  • cylindrical_farm
First blog
e14 Contributor
e14 Contributor
15 Aug 2015
We the team of “Chiraharita”  (Evergreen in sanskrit) thank element 14, Silicon labs and Würth Elektronik for choosing our proposal for the vertical farming design challenge.
Currently, the team has started off with the design of mechanical structure. We are preparing the CAD models and verifying for the best design. The team is also working on procurement of PVC components as well as manufacturing the structure.
We will be adopting a 3 stage plant growth mechanism:
  1. Seed treatment stage.
  2. Germination stage to grow seeds into saplings.
  3. And finally, the matured saplings will be transferred to the cylindrical farm.
Aeroponics is supposed to be the most efficient technique to deliver nutrients and water to plants. But we will be implementing hydroponics technique since it is less complex compared to aeroponics. However, we will be designing a structure which can operate with either of the techniques.
Congratulations to all the other challengers and All the best.
In the next post, we will explain about the germination stage and basic block diagram of working of our farm.
Stay tuned.
    shabaz over 11 years ago +1
    Hi Kowshik, There is not a lot of information here, don't forget you need high quality (in terms of content) blog posts ideally, otherwise the competition may win! Could you explain a bit more about what…
    Hello Kowshik,
    interesting project, looking forward for more details. Just as you have pointed on this, I am interested to know if it is a choice of you or it is mandatory that the seed germination phase should be in a separate condition than where the plants will grow. It is a normal condition (i.e. for tomatoes and other vegetables) applied in the traditional agriculture. I though that in the case of vertical farming this was part of the entire automated process.
    Enrico
