Vertical Farming
  • Vertical Farming
Vertical Farming
Blog Help needed with EZR32WG and EFM32
  • Author Author: ochikov
  • Date Created: 9 Sep 2015 2:28 PM Date Created
  • Views 825 views
  • Comments 11 comments
ochikov
ochikov
9 Sep 2015
Hello,
From about 3-4 days I have try to exlpore the kits. All I've done is this:
1. I managed to play example of Simplicity Studio tx-rx with EZR32WG 868 MHz kit with two nodes.
2. I managed to run Simplicity Studio energy monitoring with kit EZR32WG MHz kit
3. I managed to download the Android app and connect it with sensor-puck.
I managed to watch all about in youtube Silicon Lab's channel about our kit.
I'm not very good at C programming. I have experience only with web (PHP,MySQL).
Can somebody give me basic guideline how to deal with these kits and also how to connect sensors and etc. I will be very thankful. Also if somebody have additional documentation I will be very happy to share with me.
Thanks.
  • shanesissons
    shanesissons over 10 years ago +2
    I'm having the same issue I'm going to comment so I get email updates
  • Former Member
    Former Member over 10 years ago +2
    Hi All, I created a getting started guide in the vertical farming content to help you get off the ground (pun intended) and developing with EFM32, EZR32, and Simplicity Studio. Getting Started
  • ochikov
    ochikov over 10 years ago in reply to RWReynolds +1
    Hello Rick, Yes I have it. I only managed to run Demos on EZR32WG. I don't know where to start from. I don't have experience with C language. When I open software demos, I understand some of the written…
  • michaelwylie
    michaelwylie over 10 years ago
    Usually firmware examples come with development kits to demonstrate their capability. These are loaded through simplicity studio. When you open Simpliciy studio look on the left. It should auto detect any kit attached. Then click software examples and you should be able to select from a few example projects for the kit.
  • michaelwylie
  • ochikov
    ochikov over 10 years ago in reply to michaelwylie
    I already made all demos and examples and still can't start develop anything image
  • michaelwylie
    michaelwylie over 10 years ago in reply to ochikov
    I'm afraid you will have to know some C language and something about microcontrollers to program the device. I don't have any experience with the wireless board, but I have used the Wonder, Large, and Zero Geckos.
  • RWReynolds
    RWReynolds over 10 years ago in reply to ochikov
    Ognyan, Do you have any background in C at all? It's going to be difficult to write something at the level required if not. Especially if also have no experience with microcontrollers.
    What exactly are you thinking of doing, code wise, for your system?
  • ochikov
    I'm watching courses right now. I have experience with C#.
