Vertical Farming
  • Vertical Farming
Vertical Farming
Blog Nutrients, nutrients everywhere
  • Author Author: sftwrngnr
  • Date Created: 7 Aug 2015 7:43 AM Date Created
  • Views 785 views
  • Comments 5 comments
  • ambient_growth
sftwrngnr
sftwrngnr
7 Aug 2015
So I've noticed that several of the challengers already have experience with hydroponics, aquaponics and aeroponics. I... do not. So, I've done some due diligence, and decided that I'm going to go with General Hydroponics "Flora Series" of hydroponic nutrients.  The obvious issue, is that it's a three part solution, so my system will need to measure PH/TDS prior to anything being added, then add the appropriate quantity of each nutrient, mix the solution, and then things are good to go.  To that end, design wise, I was initially thinking peristaltic pumps, but I'm considering the possibility of using a valve based system with a measuring system.  The reason being that such a system should in theory, require less power than the peristaltic pumps.  I plan on purchasing both a peristaltic pump and a valve so that I can prototype that out at the end of the month.  I unfortunately have a work deadline that is likely going to consume the bulk of my weekends until the end of the month.
Has anyone used other brands of hydroponic nutrients, and if so, would you care to share your experiences?
  • sftwrngnr
    sftwrngnr over 11 years ago in reply to D_Hersey +1
    Wow Don! Thank you so much for your response and valuable information! OK then. Aeration system for the nutrients will be included in my build. So... I thought I may have been on the right track in terms…
  • D_Hersey
    D_Hersey over 11 years ago
    While I am opining, let me state that for the PK components, I recommend monobasic potassium phosphate.  Far more soluble than other phosphates.  Use forethought as to how you dispose of the used nutrient solution.  Pouring it down the sink can cause blooms in the sewer.  Better on the lawn, or maybe a tree.
    My plums are about ripe, just sayin'.
  • D_Hersey
  • sftwrngnr
    Wow Don!
    Thank you so much for your response and valuable information! OK then. Aeration system for the nutrients will be included in my build. So... I thought I may have been on the right track in terms of my thought process with regard to not using peristaltic pumps. I was thinking something as simple as just a piston pump for moving the nutrients around may work.  I'll continue doing my due diligence and get to building at the end of the month.
  • RWReynolds
    RWReynolds over 11 years ago in reply to sftwrngnr
    The few times I've ventured into hydroponics I used General Hydro nutrients, clay pellets and a simple fountain pump on a timer for an ebb and flow system. Worked out fine. That's what I'm using this time. Some nutrients a pump and a reservoir from a privous hydro outing.
    Just my $.02.
