Vertical Farming
  • Vertical Farming
Vertical Farming
Blog Project: ferris farm post 13
  • Author Author: shanesissons
  • Date Created: 7 Sep 2015 12:27 PM Date Created
  • Views 1246 views
  • Comments 12 comments
  • mechanical_farm
shanesissons
shanesissons
7 Sep 2015
Hand written code
here is my basic idea for the code
to be run every 5 minutes or so
If temp is above x
  activate fan 1 (relay)
if temp is below x
  deactivate fan 1
if humidity is above x
  activate fan 2
if humidity is below x
  deactivate fan 2
to be run in conjunction with the motor
when motor is in one of 4 positions (controlled by a switch being in the off position)
test soil moisture
  if moisture is below x
  activate water for 2 seconds
  deactivate water
  wait 5 minutes
repeat last 5 lines until moisture is above x
after 6 hours rotate planters 90 degrees to next planter controlled by switch
repeat steps again
x refers to variables not yet known for the plants optimal range will be a range of numbers not a single digit
  • shanesissons
    shanesissons over 11 years ago in reply to DAB +1
    rotation will be 1/4 turn every 6 hours if motorised if not it will be 1/3 turn every hours(so i can atleast get 8 hours sleep and the lighting will be on 24/7
  • shanesissons
    shanesissons over 11 years ago in reply to RWReynolds +1
    That would be great thanks rick
  • RWReynolds
    RWReynolds over 11 years ago in reply to shanesissons +1
    No problem. But you have to go like my latest blog post. LOL!
    DAB over 11 years ago
    Are you planning to synchronize the turning just during daylight hours?
    Or are you using lights to keep the growing cycle 24/7?
  • shanesissons
  • shanesissons
