Vertical Farming
  • Vertical Farming
Vertical Farming
Blog Project: ferris farm post 13
  • Author Author: shanesissons
  • Date Created: 7 Sep 2015 12:27 PM Date Created
  • Views 1251 views
  • Comments 12 comments
  • mechanical_farm
shanesissons
shanesissons
7 Sep 2015
Hand written code
here is my basic idea for the code
to be run every 5 minutes or so
If temp is above x
  activate fan 1 (relay)
if temp is below x
  deactivate fan 1
if humidity is above x
  activate fan 2
if humidity is below x
  deactivate fan 2
to be run in conjunction with the motor
when motor is in one of 4 positions (controlled by a switch being in the off position)
test soil moisture
  if moisture is below x
  activate water for 2 seconds
  deactivate water
  wait 5 minutes
repeat last 5 lines until moisture is above x
after 6 hours rotate planters 90 degrees to next planter controlled by switch
repeat steps again
x refers to variables not yet known for the plants optimal range will be a range of numbers not a single digit
  • shanesissons
    shanesissons over 11 years ago in reply to DAB +1
    rotation will be 1/4 turn every 6 hours if motorised if not it will be 1/3 turn every hours(so i can atleast get 8 hours sleep and the lighting will be on 24/7
  • shanesissons
    shanesissons over 11 years ago in reply to RWReynolds +1
    That would be great thanks rick
  • RWReynolds
    RWReynolds over 11 years ago in reply to shanesissons +1
    No problem. But you have to go like my latest blog post. LOL!
  • shanesissons
    DAB over 11 years ago
    Are you planning to synchronize the turning just during daylight hours?
    Or are you using lights to keep the growing cycle 24/7?
