Vertical Farming
  • Vertical Farming
Vertical Farming
Blog Vertical Farming Check In pt 2: Seeds, Kits and more!
  • Author Author: element14Dave
  • Date Created: 22 Aug 2015 7:18 PM Date Created
  • Views 2382 views
  • Comments 35 comments
element14Dave
element14Dave
22 Aug 2015
Vertical Farming Design Challenge
image  All About Vertical Farming
image  Overview Video
image  Prizes
image  Terms and Conditions
image  Kit List
Hey there Vertical Farming Design Challengers!
Above is a quick video talking about some updates for the Vertical Farming Design Challenge.
As mentioned in the video, please let us know when you have received your seeds in the comments section below. We will ask you all to begin the planting process on the same day once everyone has received their seeds.
Why Adriana Lettuce?
This species has been selected since it does well indoors and it has a short (48 day) maturity.  They germinate better in cooler conditions (under 75°F/24°C) – ideally between 60°-68°F (15.5-20°C)
Below is a Germination guide from the seed supplier, johnyseeds.com.
CULTURE:
Lettuce is hardy and can be planted as early as the soil can be worked. It is a cool weather crop and grows best at temperatures of 60-65°F (15.5-18.3°C). Careful variety selection is important for hot weather plantings. Sow every 3 weeks for a continuous supply of fresh lettuce.
THERMAL DORMANCY:
Lettuce seed can enter thermal dormancy when exposed to high temperatures. Optimum germination results at soil temperatures of 60°-68°F (15.5-20°C). The priming process in pelleted lettuce seeds broadens the temperature range in which the seeds will germinate, overcoming some of their thermal dormancy.
TRANSPLANTING:
Sow in flats, 4 seeds/in., or in 3/4" plug trays, barely covering seeds with fine vermiculite, 3-4 weeks before transplanting outdoors. Shade the flats on sunny, warm days if necessary to keep the soil surface cool, below 75°F (24°C), until germination. If sowing into flats, transplant 1-2" apart into flats, pots, or cell-type containers about 2 weeks later. Harden seedlings by reducing water and temperature for 2-3 days before planting outdoors. Properly hardened transplants can survive temperatures as low as 20°F (-6°C). Transplant iceberg and romaine lettuce 10-12" apart, in rows 18" apart. Other types 8-10" apart in rows 12-18" apart for full size heads or 6" apart for mini heads.
DIRECT SEEDING:
Seeds germinate even at low, 40°F (4°C), soil temperature, but poorly above 75°F (24°C) depending on the variety and seed lot. Sow seeds 1" apart, rows 12-18" apart. Cover seed lightly, about 1/8", and firm soil gently. Thin iceberg and romaine lettuce to one plant every 10-12", other types 8-10" for full size heads or 6" for mini heads. Dry soil must be watered to ensure coolness and moisture, and for uniform germination.
SALAD MIX/BABY LEAF:
Sow in a 2-4" wide band, about 60 seeds/ft.
MT0 SEEDS:
A variety's description followed by MT0-10 indicates that the seed offered for sale has been tested for the presence of Lettuce Mosaic Virus and that no LMV was found in a sample of at least 10,000 seeds. MT0-30 indicates that no LMV was found in a sample of at least 30,000 seeds.
NOTE:
A disease-free test result does not guarantee a seed lot to be disease-free, only that in the sample tested, the pathogen was not found.
DAYS TO MATURITY:
For full-size heads in mild temperatures from direct seeding; subtract 10-14 days if transplanting. Note: Maturity can be 3 or more weeks later in cool weather, and up to 1 week earlier in hot weather.
AVG. DIRECT SEEDING RATE:
For full-size heads (precision seeded): 220'/1,000 seeds, 5,300'/oz., 5.5 oz./acre 2.5" apart in rows 18" apart. For baby leaf: 16'/1,000 seeds, 400'/oz., 6,400'/lb. at 60 seeds/ft.
TRANSPLANTS:
20,000 plants/oz.
We've also pulled together a quick guide to planting seed indoors, you can find that here .
  • sftwrngnr
    sftwrngnr over 10 years ago in reply to m.ratcliffe +2
    True enough, but, as I see it, a critical aspect of the design challenge is the IoT aspect of it, which ostensibly requires the other MCU and its accompanying wireless interface. Not saying I can't have…
  • element14Dave
    element14Dave over 10 years ago +2
    Hey there Vertical Farming US challengers, I have received the 915 Mhz boards from Silicon Labs today, I'll be sending them out via UPS Next Day Air so you get them before the weekend. Sorry for the delay…
  • element14Dave
    element14Dave over 11 years ago +1
    Hello Vertical Farming challengers, We have received a few messages from people that UPS is attempting to collect duties on the seeds coming over to you. We are working to resolve the issue on our end…
  • element14Dave
    We have received a few messages from people that UPS is attempting to collect duties on the seeds coming over to you. We are working to resolve the issue on our end.
  • RWReynolds
    RWReynolds over 11 years ago in reply to element14Dave
    Hey Dave,
    You may want to check in with Ognyan Chikov. He is having some difficulty receiving his seed kit through Bulgarian customs. They are requiring a "PHYTOSANITARY CERTIFICATE" and Johhny's Selected Seeds wants $125 to provide one.
    Also, the "We've also pulled together a quick guide to planting seed indoors, you can find that here ." link seems to be broken.
    Cheers,
    Rick
  • m.ratcliffe
    m.ratcliffe over 11 years ago in reply to RWReynolds
    Is the guy at Johny Select seeds planning to retire on the back of this competition. I get similar seeds quite often for around £1.
  • RWReynolds
    RWReynolds over 11 years ago in reply to m.ratcliffe
    Wow... Same strain? Or at least similar cultivation specs?
  • m.ratcliffe
    They have the same name "Butterhead" all year round, I cant say they are exactly the same or tested for germination percent but they are £1 posted for 2000 usually. Hopefully we can arrange a planting day soon because it will be getting cold in the uk after September. Hows the growing setup coming along?
  • RWReynolds
    I think the germination date is probably 30 days out.
    It's coming along well. I got a new pump and it works great. I had one that was 70GPH with a head lift of about 30". It didn't come close to doing the job. Just got a 750GPH with a head lift of 2.7m, for the same price. That should do it, and then some. So, I'm just waiting on lights and then I can put it all together.
    My little rig is going to look sad up against some of the construction I see going on in the posts. Hopefully my electronics will count for something and l will have a good harvest. lol...
    How about you? You pretty much have everything place already don't you?
  • RWReynolds
  • shanesissons
    shanesissons over 11 years ago in reply to RWReynolds
    I have to agree with Rick on about 30 days before starting but would they have to extend the challenge as the lettuce has a 2 month grow cycle according to the post that was published seems like it will be slightly rushed I wouldnt have a problem with an extension if it came up as an option what do you think
  • m.ratcliffe
    How important is it that we all germinate on the same day, so long as the growing length is the same and we all provide an average light intensity for the grow?
    I'm just fine tuning some of the systems and automating a few other bits. Still got to get to grips with the starter MCU kit and find a home for it and get my hands on a MYSQL database to push my data to, but I had a good head start on the project. You are doing well for your first growing project, much better than my first attempt.
  • RWReynolds
    I think they are pushing the common growing period because it will make it easier for judging the competition. My thoughts anyway...
    Are you looking to create your own MySQL DB and host it locally? Or looking for some sort of cloud solution. I'm incorporating an RPi as a sort of centralized controller. And using it to log data to a cloud-based logging solution called Initial State. I'll lay the whole thing out in my next couple of blog posts.
    Have you been able to get SimplicityStudio up and running and write code for the MCU? Let me know if you need any help. I'll do what I can.
    Cheers,
    Rick
  • m.ratcliffe
    Thanks Rick, I got the Simply-studio up and running on my linux desktop, Just not had time to really have a look at what I can do with it yet. I will most likley need a bit of help in a week or so when I try to impliment it.
    I was hoping for some sort of Cloud Solution for the MySQL, Ive just checked out "initial State" Looks good but a bit pricey, I will read more into it. Good idea to blog it because it could be useful to many.
  • RWReynolds
    Let me know...
    Initial State is a bit pricey now. I got in on an introductory thing so it's not so bad. And I use it for work as well so it's worth it. There are several free Linux hosting sites out there that offer MySQL support. You generally have to implement the LAMP stack yourself and any DB and applications you want. I'm sure there's something like Initial State for free. They were when they were in beta.
