Vertical Farming
  • Vertical Farming
Vertical Farming
Documents Vertical Farming Design Challenge - Kit List
  • Author Author: element14Dave
  • Date Created: 1 Jun 2015 4:48 PM Date Created
  • Last Updated Last Updated: 15 Jun 2015 3:55 PM
  • Views 5486 views
  • Likes 10 likes
  • Comments 41 comments
image  About this Challenge
image  All About Vertical Farming
image  Prizes
image  Overview Video
image  Terms and Conditions
Challengers!
It is time to Grow Up! Observations and forecasts from leading publications point to the need to increase our ability to grow fresh food in urban areas – closer to the populations that will consume them.  This means shifting from traditional outdoor gardens to indoor systems for food production.  Electronic Engineers are uniquely suited to provide systems based on a technology infrastructure that can lessen required energy consumption in production and improve the output of a smaller space.
To get you started on your challenge journey we have a base-kit that you can work with and from. How you put these into practice is entirely up to you. This is a good collection of equipment for you to sink your soldering iron into, feel free to hack away, apart or together any component as you see fit.
{gallery} Vertical Farming
Silicon Labs EZR32WG 868MHz Wireless Starter Kit
Silicon Labs Sensor Puck - SENSOR-PUCK board
Silicon Labs EFM32 Zero Gecko Starter Kit
Würth Elektronik Design Kits- Capacitors 885 080, 885 070, 885 060
Würth Elektronik Design Kit - Switches- 499 001
Würth Elektronik Design Kit - LEDs 150 151
Würth Elektronik Design Kit - Power Inductors  744 383
EFM32G_sensor_puck.zip
imagewstk6220_EZR32WG_868MHz_Wireless_Starter_Kit (1).pdf
imageefm32zg-stk3200-ug.pdf
  • vertical
  • Design
  • challenge
  • farming
  • list
  • kit
  • sleuz
    sleuz over 11 years ago +5
    Hi guys due to the high demand for our switches, we currently face a shortage on some of these components. As half a kit looks kind of silly, we decided to leave them out of the bundle. However, please…
  • sleuz
    sleuz over 11 years ago in reply to morantz +4
    Hi Dan, as far as our LED portfolio is concerned, we offer standard signal and backlight LEDs . All contestants will receive one of our LED Kits with an overview of our LED components. For any lights or…
  • element14Dave
    element14Dave over 11 years ago in reply to mcb1 +3
    I have updated this page with the correct SKU list and supporting documentation on the Sensor Puck and the EZR32WG 898MHz Wireless Sensor Kit.
  • m.ratcliffe
    m.ratcliffe over 11 years ago in reply to RWReynolds
    Thanks for the update Rick.
    Back to salvaging some switches from some other stuff then. The rest of the kit is awesome, I'm having a play around with it now.
  • RWReynolds
    RWReynolds over 11 years ago in reply to m.ratcliffe
    Don't know exactly what the issue was but Wurth is not going to provide the switch kit.
    Check this video out. Dave explains it.
    http://www.element14.com/community/videos/17179/l/Vertical-Farming-Design-Challenge-Check-In
  • m.ratcliffe
    element14Dave
    Hi Dave, I think I got sent an extra capacitor kit instead of the switch kit.
    Hi,
    Does the Sensor Puck broadcast data as a beacon?. I mean UUID, Major and Minor.
    Best regards,
    Camilo.
    e14 Contributor over 11 years ago in reply to e14 Contributor
    Good point, Jeremy. I think growers often underestimate the importance of spectral quality and light intensity as a role in plant growth. I've experimented with just about every type of horticultural lighting, though and I've seen plenty of impressive results from artificial light sources so don't count them out!  LEDs from various manufacturers are offered in many different spectral distributions depending on the overall needs of the plant and goals of the grower. I'd love to talk more about this and answer questions anyone has about lighting for their systems. -Tim
    e14 Contributor over 11 years ago in reply to morantz
    The two kinds of Chlorophyll found in plants is named A and B (very creative, I know), and they absorb light in the red and blue portions of the spectrum. However, there are many other light-sensitive molecules contained within and used by plants. Some plant hormones that control flowering rely on UV light, some plant hormones that control foliage density rely on IR light, etc. Consequently plants can grow with only red and blue, but they won't look as full/healthy as a plant receiving full-spectrum lighting from the sun. The second major advantage of sunlight is that light intensity (and thus plant energy) decreases with the square of the distance to the source (similar to other energy sources such as sound). So the sun will be equally intense at the top or bottom of a plant, but artificial lighting will be considerably less intense at the bottom of the plant.
    Reference wikipedia: https://en.wikipedia.org/wiki/Chlorophyll#/media/File:Chlorophyll_ab_spectra-en.svg
    Do we get any advance knowledge of the seeds to be used? Different plants have different needs in terms of optimised design, so the plant type could easily have a dramatic effect on design.
    Thanks.
    I'm all about farming in small spaces and I found out about this after it started. Any way I can join in now
  • sleuz
    Hi Dan, as far as our LED portfolio is concerned, we offer standard signal and backlight LEDs. All contestants will receive one of our LED Kits with an overview of our LED components.
    For any lights or lamps you propably need to get it yourself. Otherwise you can still let the sun do the job! image
    mcb1 over 11 years ago in reply to element14Dave
    element14Dave
    Thanks Dave, that could be very useful to some contestants.
    It's great to see the other frequencies are available as we discovered in the Forget Me Not challenge, 434, 868, and 902 MHz are not available in Australia and 902 MHz in some other countries.
    The challenge involves using the supplied kit, but if anyone wants to add additonal RF units, electronichamsters ( Eric ) introduced some very interesting options (covered in his summary)
    http://www.element14.com/community/community/design-challenges/forget-me-not/blog/2014/10/22/eric-tsai--final-blog-post
